Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2396 Fragen Alle anzeigen
iPhone 4 only works on charger
i have an iPhone 4 which appears to only work on the charger. as soon as it has been removed from the charger it turns off. and you can't do a thing with it unless on the charger. i was just wondering what the problem is, how to fix it, and what part/s i need.
i hope you can help!
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Ok thanks, i will see how i go!
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
I have the same problem.....apparently is a bad battery or bad dock connector. I haven't had the time to try and fix it. So what I suggest is take your iPhone apart and reassemble it, to make sure everything is as it should be!
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
IF that does not work :) start with the easy thing and replace the battery. Should it not charge, replace the dock connector. Follow these guides iPhone 4
von
Try replacing the battery. It's a relatively cheap and easy fix and seemed to help my iphone 4. Good luck and hope it helps!
Bewertung 0
Antwort hinzufügen
Brice wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 4,967
