Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
I had my digitizer replaced and now the phone won't charge
I took my phone in to have digitizer replaced which was done but the phone won't charge now. The repair guy looked at it and said he could fix it saying it was a pin up by the camera, then he said he fixed a bent wire by the charge point and now he doesn't know what to do - any suggestions. I am now worried that the guy at this shop didn't really know what he was doing.
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare:
You asked this question in July, are you still having problems ?
von
Hi, one thing I would like the say to the answer above is there is no reason for anyone to come here if they were contact Apple or any OEM for repairs!!!!
I would suggest that u see pictures of the motherboard here or on the web and see if there is anything missing or out of place. Use a magnifying glass to carefully analyze what is wrong. Write back on what u did. Good luck.
von
Einen Kommentar hinzufügen
1 Antwort
The best way to do anything that involves something from Apple, would be to contact the customer service directly and talk to the company and talk directly to someone that is used to repair those problems. i wish i could help more than pointing you to the right direction but it's all i could do. Also, try to head to some Apple sub station, they can also help a bit by sending you to the right people.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Downvotes should be reserved for malicious or blatantly wrong and misleading answers. Even so it is not a very helpful answer to the original question, it is an answer without malice.
von
Antwort hinzufügen
anastasia mayette wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 624
