Zum Hauptinhalt wechseln
Modell von 2011, A1278 / 2,3 GHz i5 oder 2,7 GHz i7 Prozessor
782 Fragen Alle anzeigen
Pieces missing on logic board
My macbook had a little fall to the ground and after that it did not want to start up.
It does power up, and the white light goes on. But nothing on the screen.
So i took the back panel off and took a look around. I saw 2 missing pieces on the logic board. 2 small square resistors i guess.
My question is if these are possible to fix? I did not find the ones that where broken off.
Anyone know what type or where i can get this "resistors"?
Or can i just solder on some wire
Eric
Ist dies eine gute Frage?
Bewertung 1
5 Kommentare
You may get a bit more help if you at least post an image of where the components are. It is not clear by your description what components could be missing.
von
+ what he said - resistors (and other parts) have color codes to help identify them. A clear sharp image of them, and where you think they may have popped off from would be very helpful. The more information you provide, the more assistance we can give
von
Here is a picture of the missing parts. Marked out in red: http://i672.photobucket.com/albums/vv81/...
von
I have now got solderd on the parts that fell off. And still nothing.
I have not tried heating it. That could do the trick. Thanks :)
von
Have you made sure the pieces were aligned appropriately? As in (+) and (-).
What part hit the ground first?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
If nothing works as you tired soldering so far, give a try directly connecting two ends of each fallen off capacitors. See if that works.
War diese Antwort hilfreich?
Bewertung 1
Those look more like capacitors to me.
Although the probability of them falling off is very small.
Have you tried running the mainboard out of the case and heating it up with a heat gun? Sometimes that works.
Bewertung 0
Antwort hinzufügen
Eric wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 979
