Door handle replacement repair
How do I replace door handle?
Ist dies eine gute Frage?
Gerald Andeson, try this:
"There are ten Phillips screws on the inside of the dryer door. To get at the screws holding the door handle in place, you have to remove the face plate on the door front. To do this, only six of the ten Phillips screws need to be removed. There is no need to remove any of the Torx screws.
Remove the two Phillips screws at the top and the two Phillips screws at the bottom. You are now left with six Phillips screws - three on each side. Now remove the middle Phillips screw on each side of the door. The front face plate on the door can now be removed to get access to the screws holding the door handle in place.
Remove the two screws holding the broken handle in place and remove the broken handle. Screw the new handle in place. Now reverse the procedure above to reattach the face plate. Since the six screws that were removed are all identical, you need not worry about which screw goes where.
Notes:
1: Of the remaining four Phillips screws that you need not remove, two attached the door hinge to the door and the other two just fill a hole. The two "filled holes" is where the door hinge would be attached should you wish to reverse the direction of the door swing.
2: The replacement door handle is the same part regardless of the door swing direction. from here. Hope this helps, good luck.
War diese Antwort hilfreich?
Great! Simple and perfect!
Perfect how to. Thanks.
Right on. Five minute job! Thanks!
So helpful! Thanks! Perfect and simple instructions!
Thanks so much for providing this information. I would have never figured it out and wasn’t able to find any instructions. Great help!!!
Letzte 24 Stunden: 6
Letzte 7 Tage: 23
Letzte 30 Tage: 53
Insgesamt: 7,134
1 Kommentar
Hi the handle on my Kenmore Elite front load dryer is broken and unable to open the door to unscrew anything...pls advise
von Sundara Jangam
