Zum Hauptinhalt wechseln
Asus MeMO Pad 8 ME181C Motherboard Replacement
Was du brauchst
  1. Asus MeMO Pad 8 ME181C Motherboard Replacement, Rear Case: Schritt 1, Bild 1 von 2 Asus MeMO Pad 8 ME181C Motherboard Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool into the seam between the rear case and the screen.
    • Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
  2. Asus MeMO Pad 8 ME181C Motherboard Replacement, Battery: Schritt 2, Bild 1 von 3 Asus MeMO Pad 8 ME181C Motherboard Replacement, Battery: Schritt 2, Bild 2 von 3 Asus MeMO Pad 8 ME181C Motherboard Replacement, Battery: Schritt 2, Bild 3 von 3
    • Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion Force (ZIF) connector holding the orange motherboard ribbon cable in place.
  3. Asus MeMO Pad 8 ME181C Motherboard Replacement: Schritt 3, Bild 1 von 2 Asus MeMO Pad 8 ME181C Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Use the flat end of the nylon spudger to flip up the retaining flap of the ZIF connector holding the black motherboard ribbon cable in place.
  4. Asus MeMO Pad 8 ME181C Motherboard Replacement: Schritt 4, Bild 1 von 2 Asus MeMO Pad 8 ME181C Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use the pointed end of the nylon spudger to pop up the battery connector.
    • When reconnecting the battery cable after replacing the battery, press the battery connector with your finger until it clicks into place.
  5. Asus MeMO Pad 8 ME181C Motherboard Replacement: Schritt 5, Bild 1 von 2 Asus MeMO Pad 8 ME181C Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use the flat end of the nylon spudger to pry up the battery.
    • The battery is secured with adhesive. Some force is required to detach battery from the device.
    • If removing motherboard is necessary, it may be easier complete this step with the motherboard simultaneously later.
  6. Asus MeMO Pad 8 ME181C Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Working from top to bottom, you will remove all screws with a #000 Phillips head driver, (20) total.
    • (2) screws located in the top corners. NOTE: These screws will be in the speakers.
    • (4) screws located along the top of the battery, (3) along each side of the battery, and (3) along the bottom of the battery.
    • (1) screw in the middle of the motherboard on the side with the orange ribbon cable, (4) screws in the bottom of the motherboard .
  7. Asus MeMO Pad 8 ME181C Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Make sure that the battery is disconnected from the motherboard by unplugging the ribbon cables.
  8. Asus MeMO Pad 8 ME181C Motherboard Replacement: Schritt 8, Bild 1 von 2 Asus MeMO Pad 8 ME181C Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Before you remove the entire assembly, first unplug side buttons and cameras from the motherboard using tweezers.
    • The motherboard is easiest to remove simultaneously with the battery. Refer to Step 5 for more details.
  9. Asus MeMO Pad 8 ME181C Motherboard Replacement: Schritt 9, Bild 1 von 2 Asus MeMO Pad 8 ME181C Motherboard Replacement: Schritt 9, Bild 2 von 2
    • While the device is open, this is your opportunity to check and see if there is any other damage to the motherboard or other associated parts.
Abschluss
emm4
154 Reputation
1 Anleitung geschrieben
USF Tampa, Team 5-6, Lacy Fall 2016 Mitglied von USF Tampa, Team 5-6, Lacy Fall 2016
USFT-LACY-F16S5G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 1,761
