Zum Hauptinhalt wechseln
Asus TF300T Tablet Charging Port Replacement
Was du brauchst
  1. Asus TF300T Tablet Charging Port Replacement, Back Panel Removal: Schritt 1, Bild 1 von 3 Asus TF300T Tablet Charging Port Replacement, Back Panel Removal: Schritt 1, Bild 2 von 3 Asus TF300T Tablet Charging Port Replacement, Back Panel Removal: Schritt 1, Bild 3 von 3
    • Begin the process by making sure that the dock is disconnected and the power is turned off.
    • Start by using the plastic opening tool on the side opposite the dock/ charging port. Begin to open the device along the short sides of the tablet.
    • When you have reached the side with the charging/ dock port be gentle with the opening tool due to the thinner plastic that could be broken with excessive force.
    • Once the opening tools have completely made their way around the device use the spudger to separate the back panel from the screen and expose the inside.
  2. Asus TF300T Tablet Charging Port Replacement, Turn Off the Power: Schritt 2, Bild 1 von 1
    • The Asus Transformer series tablets have a hard power switch. This should be turned off before working on the tablet.
    • Locate the power switch near the power button on the top left. Use a tool to slide it to the position marked 'off'
    • For many repairs, like replacing the screen or digitizer, you do not need to remove the battery once you hve turned the tablet off. Be very careful not to short anything out with metal tools!
  3. Asus TF300T Tablet Charging Port Replacement, Battery Removal: Schritt 3, Bild 1 von 3 Asus TF300T Tablet Charging Port Replacement, Battery Removal: Schritt 3, Bild 2 von 3 Asus TF300T Tablet Charging Port Replacement, Battery Removal: Schritt 3, Bild 3 von 3
    • Using the Phillips #00 screwdriver remove all of the screws connecting the battery to the mother board.
    • Once the initial screws have been removed as indicated by the photo, use the spudger to remove the cover concealing the the clips for the dock sensor and a few more screws.
    • Again remove the screws with the same screwdriver and use the spudger to disconnect the spudger sesors from their respective clips.
    • Once the battery is freed use the spudger to remove the battery from its spot
  4. Asus TF300T Tablet Charging Port Replacement, Charging Port: Schritt 4, Bild 1 von 1
    • With the battery removed, the charging strip is freely accessible with tweezers. Carefully flip up the white retaining flap on the cable's ZIF connector, and slide the cable out.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Jonathan Barros
1.231 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 2-6, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 2-6, Duarte Fall 2014
UMASSD-DUARTE-F14S2G6
4 Mitglieder
10 Anleitungen geschrieben
3 Kommentare
I have a bad charging port on my Asus tablet and bought all the tools described in this tutorial. However the phillips screwdriver recommended is too pointed and will not unscrew any of the internal screws so I could not get very far. Very frustrating. Anyone know which one would work without buying a whole screwdriver kit?
Also, author shows removing battery in order to replace the charging port but wondering if it can be replaced without removing battery. Would save time and make it easier but I'm just guessing since I couldn't even get the screws out at this point.
bgowgiel - Antwort
To change the charging port, you don't necessary have to remove the battery. You can carrefully change the charging port using a tiny flat screwdriver to translate the strip out of it's place. (excuse my English, i'm french).
So, very good tutorial, it's help me a lot !
targo14 - Antwort
I think if this is a older machine it would be a good idea to replace the battery at the same time as replacing the charging port, might eliminate problems later.
Teddy Banks - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 39
Insgesamt: 14,777
