Zum Hauptinhalt wechseln
Asus VivoBook X540SA-BPD0602V Battery Removal
Was du brauchst
  1. Asus VivoBook X540SA-BPD0602V Battery Removal, Keyboard: Schritt 1, Bild 1 von 1
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Asus VivoBook X540SA-BPD0602V Battery Removal: Schritt 2, Bild 1 von 1
    • Flip the laptop over so the back panel is displayed.
  3. Asus VivoBook X540SA-BPD0602V Battery Removal: Schritt 3, Bild 1 von 1
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Asus VivoBook X540SA-BPD0602V Battery Removal: Schritt 4, Bild 1 von 1
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Asus VivoBook X540SA-BPD0602V Battery Removal: Schritt 5, Bild 1 von 1
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Asus VivoBook X540SA-BPD0602V Battery Removal: Schritt 6, Bild 1 von 1
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
  7. Asus VivoBook X540SA-BPD0602V Battery Removal, Battery: Schritt 7, Bild 1 von 1
    • Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
    • The batteries should all be connected to one another and come out of the device as a single unit.
    • Be careful not to rip any of the black plastic covering the batteries. Exposed battery parts can lead to explosions. If the case is ripped, re-wrap them, or properly dispose of them. Do not reuse them.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team S1-G111, Cagle Fall 2017 Mitglied von USF Tampa, Team S1-G111, Cagle Fall 2017
USFT-CAGLE-F17S1G111
5 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
Easy, and nice guide.
To be honest you don't need make pint 6 - unplug keyboard and pad cable. You can just move cover a bit to your side (pull into your direction) then you will get a lot space to pull out battery.
Damian Gepard - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 77
Insgesamt: 9,334
