Einleitung
Taking out the battery is easy to replace when needed. It may need to be replaced if the battery dies quickly.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Was du brauchst
Remove the five 3mm screws on the battery with a Torx (T8) screwdriver in the locations shown.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
