Zum Hauptinhalt wechseln
HP Elite X2 1013 G3 Battery Replacement
Was du brauchst
  1. HP Elite X2 1013 G3 Battery Replacement, Screen: Schritt 1, Bild 1 von 1
    • Flip the device over so the base is facing the ceiling.
    • Lift up the tablet stand.
    • Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
  2. HP Elite X2 1013 G3 Battery Replacement: Schritt 2, Bild 1 von 2 HP Elite X2 1013 G3 Battery Replacement: Schritt 2, Bild 2 von 2
    • Flip the tablet over with the screen facing upwards.
    • Place the suction handle in the center of the screen and slowly lift off the screen until it is at a 30 degree angle, starting by gently prying up the bottom.
    • Do not pull the screen beyond a 30 degree angle. Additional internal components must be disconnected first.
  3. HP Elite X2 1013 G3 Battery Replacement: Schritt 3, Bild 1 von 2 HP Elite X2 1013 G3 Battery Replacement: Schritt 3, Bild 2 von 2
    • With the screen lifted at a 30 degree angle, gently disconnect the yellow ribbon cable at the end connected to the screen.
    • Gently disconnect the orange ribbon cable at the end connected to the bottom plate.
  4. HP Elite X2 1013 G3 Battery Replacement: Schritt 4, Bild 1 von 2 HP Elite X2 1013 G3 Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the screen from the tablet.
  5. HP Elite X2 1013 G3 Battery Replacement, Battery: Schritt 5, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the six 2 mm screws.
    • Gently disconnect the two connectors.
  6. HP Elite X2 1013 G3 Battery Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery out of the housing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team S9-G12, Maness Spring 2019 Mitglied von Cal Poly, Team S9-G12, Maness Spring 2019
CPSU-MANESS-S19S9G12
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 64
Insgesamt: 2,477
