Zum Hauptinhalt wechseln
HTC Vive Cosmos headstrap Pads Replacement
Was du brauchst
  1. HTC Vive Cosmos headstrap Pads Replacement, Remove the rear headstrap pads: Schritt 1, Bild 1 von 3 HTC Vive Cosmos headstrap Pads Replacement, Remove the rear headstrap pads: Schritt 1, Bild 2 von 3 HTC Vive Cosmos headstrap Pads Replacement, Remove the rear headstrap pads: Schritt 1, Bild 3 von 3
    • Grasp the rear headstrap pad on one end and pull it away from the headstrap to remove it.
    Frag FixBot
  2. HTC Vive Cosmos headstrap Pads Replacement, Remove the front headstrap pad: Schritt 2, Bild 1 von 3 HTC Vive Cosmos headstrap Pads Replacement, Remove the front headstrap pad: Schritt 2, Bild 2 von 3 HTC Vive Cosmos headstrap Pads Replacement, Remove the front headstrap pad: Schritt 2, Bild 3 von 3
    • Grasp the front headstrap pad on one end and pull it away from the headstrap to remove it.
    • During reassembly, press the pads firmly against the headstrap, starting in the middle and moving toward the edges, until all the clips on the pads are completely seated in the headstrap. There should be no gaps between the pads and the headstrap.
    Frag FixBot
Abschluss
Adam O'Camb
222.774 Reputation
416 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 51
Insgesamt: 617
