Zum Hauptinhalt wechseln
LG G8 ThinQ Screen Replacement
Was du brauchst
  1. LG G8 ThinQ Screen Replacement, SIM Card Tray: Schritt 1, Bild 1 von 3 LG G8 ThinQ Screen Replacement, SIM Card Tray: Schritt 1, Bild 2 von 3 LG G8 ThinQ Screen Replacement, SIM Card Tray: Schritt 1, Bild 3 von 3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Screen Replacement, Back Panel: Schritt 2, Bild 1 von 3 LG G8 ThinQ Screen Replacement, Back Panel: Schritt 2, Bild 2 von 3 LG G8 ThinQ Screen Replacement, Back Panel: Schritt 2, Bild 3 von 3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Screen Replacement, Midframe: Schritt 3, Bild 1 von 3 LG G8 ThinQ Screen Replacement, Midframe: Schritt 3, Bild 2 von 3 LG G8 ThinQ Screen Replacement, Midframe: Schritt 3, Bild 3 von 3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Screen Replacement, Speaker System: Schritt 4, Bild 1 von 3 LG G8 ThinQ Screen Replacement, Speaker System: Schritt 4, Bild 2 von 3 LG G8 ThinQ Screen Replacement, Speaker System: Schritt 4, Bild 3 von 3
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
  5. LG G8 ThinQ Screen Replacement, Front Cameras: Schritt 5, Bild 1 von 2 LG G8 ThinQ Screen Replacement, Front Cameras: Schritt 5, Bild 2 von 2
    • Using an opening tool, carefully disconnect the ribbon cables from both cameras.
  6. LG G8 ThinQ Screen Replacement: Schritt 6, Bild 1 von 3 LG G8 ThinQ Screen Replacement: Schritt 6, Bild 2 von 3 LG G8 ThinQ Screen Replacement: Schritt 6, Bild 3 von 3
    • Using an opening tool, carefully pry up and remove both cameras from the phone casing.
  7. LG G8 ThinQ Screen Replacement, Headphone Jack: Schritt 7, Bild 1 von 3 LG G8 ThinQ Screen Replacement, Headphone Jack: Schritt 7, Bild 2 von 3 LG G8 ThinQ Screen Replacement, Headphone Jack: Schritt 7, Bild 3 von 3
    • Using an opening tool, carefully disconnect the ribbon cable connecting the 3.5mm audio jack to the motherboard.
    • Remove the screw holding the 3.5 mm audio jack in place using a Phillips #000 screwdriver.
    • Remove the audio jack from the phone.
  8. LG G8 ThinQ Screen Replacement, Battery: Schritt 8, Bild 1 von 1
    • Flip phone so that screen is facing up.
    • Using a heating pad, hairdryer, or heat gun, apply heat to loosen the adhesive beneath the battery.
    • Be careful to not overheat the phone; the screen and battery are susceptible to damage.
    • The adhesive can be difficult to soften; it may take many attempts.
  9. LG G8 ThinQ Screen Replacement: Schritt 9, Bild 1 von 2 LG G8 ThinQ Screen Replacement: Schritt 9, Bild 2 von 2
    • Using an opening tool, carefully pry up the ribbon cable to disconnect the battery.
  10. LG G8 ThinQ Screen Replacement: Schritt 10, Bild 1 von 3 LG G8 ThinQ Screen Replacement: Schritt 10, Bild 2 von 3 LG G8 ThinQ Screen Replacement: Schritt 10, Bild 3 von 3
    • Using opening cards or an opening tool, carefully pry around the edges of the battery.
    • If you have trouble prying up the battery, the adhesive may not be loose enough. Re-apply heat, or use some isopropyl alcohol under the battery, allowing it to penetrate for several minutes to weaken the adhesive.
    • Remove the battery from the phone.
  11. LG G8 ThinQ Screen Replacement, Motherboard: Schritt 11, Bild 1 von 2 LG G8 ThinQ Screen Replacement, Motherboard: Schritt 11, Bild 2 von 2
    • Use an opening tool to disconnect the two coaxial cables from the motherboard.
  12. LG G8 ThinQ Screen Replacement: Schritt 12, Bild 1 von 3 LG G8 ThinQ Screen Replacement: Schritt 12, Bild 2 von 3 LG G8 ThinQ Screen Replacement: Schritt 12, Bild 3 von 3
    • Using an opening tool, carefully disconnect the screen ribbon cable from the motherboard.
    • Using an opening tool, carefully pry up the motherboard from the frame and remove it from the phone.
  13. LG G8 ThinQ Screen Replacement, Vibration Motor: Schritt 13, Bild 1 von 2 LG G8 ThinQ Screen Replacement, Vibration Motor: Schritt 13, Bild 2 von 2
    • Remove the vibration motor from the phone casing using an opening tool.
    • Heat the vibration motor from the other side of the phone to loosen adhesive if needed.
  14. LG G8 ThinQ Screen Replacement, Screen: Schritt 14, Bild 1 von 3 LG G8 ThinQ Screen Replacement, Screen: Schritt 14, Bild 2 von 3 LG G8 ThinQ Screen Replacement, Screen: Schritt 14, Bild 3 von 3
    • Using a plastic spudger, carefully pry up and remove the charging daughter board from the case.
    • Reinstall removed components onto new phone casing and screen.
Abschluss
To reassemble your device, follow these instructions in reverse order, installing the components on your new screen.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Josh Cress
458 Reputation
2 Anleitungen geschrieben
2 Kommentare
I did not do this myself, but I now see the labor involved, in addition to the rarity of LG phones. Meaning, I understand why it costs what it does for a professional to do this.
Jane Walsh - Antwort
Hi. I had my screen replaced a few months back. It was repaired by a friend who has been working in the repair industry for most of the past decade. However, the under screen fingerprint scanner no long functions. What is causing this, and how can I fix it? Thanks
Jo Payne - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 35
Letzte 30 Tage: 150
Insgesamt: 6,396
