Zum Hauptinhalt wechseln
Lenovo 500e Chromebook 2nd Gen Battery Replacement
Was du brauchst
  1. Lenovo 500e Chromebook 2nd Gen Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Battery Replacement: Schritt 2, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Battery Replacement: Schritt 3, Bild 2 von 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Battery Replacement, Battery: Schritt 4, Bild 1 von 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Battery Replacement: Schritt 5, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Battery Replacement: Schritt 5, Bild 2 von 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery from the laptop.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 495
