Zum Hauptinhalt wechseln
Lenovo 500e Chromebook 2nd Gen Motherboard Replacement
Was du brauchst
  1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 2, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 3, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Battery: Schritt 4, Bild 1 von 1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 5, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: Schritt 7, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: Schritt 7, Bild 2 von 2
    • Remove the three 4 mm screws (six total) from the left and right side brackets using a Phillips #00 screwdriver.
    • Gently remove the metal brackets from the motherboard.
  8. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 8, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Remove the nine 4 mm screws from the motherboard using a Phillips #00 screwdriver.
  9. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 9, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Gently remove the USB port from the side housing using an iFixit opening tool.
  10. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 10, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Gently peel the metal strip away from the metal backing.
  11. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Remove the single 3 mm screw that holds the Wi-Fi card in place using a Phillips #00 screwdriver.
  12. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 12, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Disconnect the Wi-Fi card from the motherboard using an iFixit opening tool.
  13. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 13, Bild 1 von 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 13, Bild 2 von 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Using an iFixit opening tool, disconnect the camera cable.
    • Potential for device damage: Be gentle while removing the wire.
  14. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 14, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Using an iFixit opening tool, detach the speaker wiring from the motherboard.
    • Set speakers aside for reinstallation.
  15. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 15, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Using an iFixit opening tool, detach the track pad connector from the motherboard.
    • Potential for device damage: Be gentle while detaching the connector.
  16. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 16, Bild 1 von 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 16, Bild 2 von 3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 16, Bild 3 von 3
    • Using an iFixit opening tool, detach the keyboard cable from the motherboard.
    • Potential for device damage: Be gentle when detaching the cable.
  17. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 17, Bild 1 von 2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 17, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using tweezers, disconnect the black cable from the motherboard.
    • Potential for device damage: Be gentle while detaching the cable.
  18. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Gently remove the motherboard from the laptop.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 7
Letzte 30 Tage: 47
Insgesamt: 742
