Zum Hauptinhalt wechseln
Lenovo IdeaPad Flex 5-1570 Touchpad Replacement
Was du brauchst
  1. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Back Panel: Schritt 1, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 2, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 2, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 2, Bild 3 von 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 3, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 3, Bild 2 von 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Battery: Schritt 4, Bild 1 von 2 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 5, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 5, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 5, Bild 3 von 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: Schritt 6, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: Schritt 6, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement, Touchpad: Schritt 6, Bild 3 von 3
    • Using the plastic opening tool, unlock the four ZIF connectors to release the flat cables.
    • Disconnect the four flat cables from the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 7, Bild 1 von 1
    • Using the JIS #000 screwdriver, remove six 2mm screws holding the trackpad down to the device.
  8. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 8, Bild 1 von 1
    • Using the plastic opening tool, remove the silver piece of tape holding the touchpad to the device.
  9. Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 9, Bild 1 von 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 9, Bild 2 von 3 Lenovo IdeaPad Flex 5-1570 Touchpad Replacement: Schritt 9, Bild 3 von 3
    • Insert the plastic opening tool underneath the touchpad.
    • Lift it up and remove the touchpad from the device.
Abschluss
Justin Ogihara
27.209 Reputation
52 Anleitungen geschrieben
EDU Team Mitglied von EDU Team
Staff
7 Mitglieder
637 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 50
Insgesamt: 1,451
