Was du brauchst
Power off the laptop and place it face-down on a non-scratching surface.
Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
Slide a plastic opening tool underneath the back case near the screen hinges.
Gently pry up on either side of the case.
Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
Using an opening tool, lift up on the black and white coaxial cables on the Wi-Fi card and gently pull upward to unplug them.
Remove the single 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
Gently lift the Wi-Fi card out of the computer.
