Zum Hauptinhalt wechseln
Lenovo Legion Y7000P Back Cover Replacement
Was du brauchst
  1. Lenovo Legion Y7000P Back Cover Replacement, Flip your laptop over: Schritt 1, Bild 1 von 1
    • Flip your laptop over so the rubber feet are facing up.
  2. Lenovo Legion Y7000P Back Cover Replacement, Unfasten the back cover: Schritt 2, Bild 1 von 2 Lenovo Legion Y7000P Back Cover Replacement, Unfasten the back cover: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 11 screws securing the back cover:
    • Five 11.5 mm‑long screws
    • Six 4.7 mm-long screws
  3. Lenovo Legion Y7000P Back Cover Replacement, Insert an opening pick: Schritt 3, Bild 1 von 2 Lenovo Legion Y7000P Back Cover Replacement, Insert an opening pick: Schritt 3, Bild 2 von 2
    • Insert the flat side of an opening pick between the top right corner of the back cover and frame.
  4. Lenovo Legion Y7000P Back Cover Replacement, Release the back cover's clips: Schritt 4, Bild 1 von 3 Lenovo Legion Y7000P Back Cover Replacement, Release the back cover's clips: Schritt 4, Bild 2 von 3 Lenovo Legion Y7000P Back Cover Replacement, Release the back cover's clips: Schritt 4, Bild 3 von 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Keep the pick angled upwards while sliding to help release the clips.
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  5. Lenovo Legion Y7000P Back Cover Replacement: Schritt 5, Bild 1 von 3 Lenovo Legion Y7000P Back Cover Replacement: Schritt 5, Bild 2 von 3 Lenovo Legion Y7000P Back Cover Replacement: Schritt 5, Bild 3 von 3
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  6. Lenovo Legion Y7000P Back Cover Replacement, Remove the back cover: Schritt 6, Bild 1 von 3 Lenovo Legion Y7000P Back Cover Replacement, Remove the back cover: Schritt 6, Bild 2 von 3 Lenovo Legion Y7000P Back Cover Replacement, Remove the back cover: Schritt 6, Bild 3 von 3
    • Remove the back cover.
  7. Lenovo Legion Y7000P Back Cover Replacement, Reassembly information: Schritt 7, Bild 1 von 3 Lenovo Legion Y7000P Back Cover Replacement, Reassembly information: Schritt 7, Bild 2 von 3 Lenovo Legion Y7000P Back Cover Replacement, Reassembly information: Schritt 7, Bild 3 von 3
    • During reassembly:
    • Slide the two tabs near the center of the back cover's top edge under the hinge cover.
    • Press down firmly around the perimeter of the back cover to engage all the clips.
Abschluss
Spencer Day
54.989 Reputation
407 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.303 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 135
