Einleitung
How to replace the battery of a Lenovo Yoga 710-14ISK laptop. The images and information in this guide were taken from this computer's service manual.
Was du brauchst
Remove the M2 × 7 mm, Torx-head screws.
Remove the M2 × 5 mm, Torx-head screws.
Insert a prying tool (opening pick) between the base cover and the cover and slide it in the direction shown by arrows to separate the base cover from the cover.
Remove the base cover.
Unplug the battery connector.
Remove the M2 × 3 mm, Phillips-head screws.
Remove the battery pack.
To replace the battery & reassemble your device, follow these instructions in reverse order.
Ein Kommentar
Hi, do i can replace my laptop battery by myself? or i should go to geek squad in best buy.
