Zum Hauptinhalt wechseln
Lenovo Yoga 710-15IKB Battery Replacement
Was du brauchst
  1. Lenovo Yoga 710-15IKB Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the ten 3.3 mm T5 screws from the base cover.
    • The screws aren't all the same length. Be sure to keep the screws sorted as you work.
  2. Lenovo Yoga 710-15IKB Battery Replacement: Schritt 2, Bild 1 von 1
    • Slide an opening tool between the base and back cover and work your way around the entire device to release the back cover.
  3. Lenovo Yoga 710-15IKB Battery Replacement: Schritt 3, Bild 1 von 1
    • Lift and remove the back cover.
  4. Lenovo Yoga 710-15IKB Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #1 screwdriver.
  5. Lenovo Yoga 710-15IKB Battery Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the battery by pulling its cable away from the hinge with a pair of tweezers or your fingers.
  6. Lenovo Yoga 710-15IKB Battery Replacement: Schritt 6, Bild 1 von 1
    • Gently lift and remove the battery.
Abschluss
15 weitere Nutzer:innen haben diese Anleitung absolviert.
University of Maine, Team S1-G5, Diaz Fall 2017 Mitglied von University of Maine, Team S1-G5, Diaz Fall 2017
UMAINE-DIAZ-F17S1G5
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
I had to use a PH000 screwdriver and was only able to remove 1 of the battery screws from the original Lenovo battery. Any suggestions on how to remove the others? Where can I get replacement screws?
karenosickey - Antwort
The battery cable requires a lot of force to disconnect; tweezers won't cut it. It's also difficult to reconnect the battery. I used two pairs of needle-nose pliers to squeeze the connector into the socket on both sides.
jkvmyxud - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 96
Insgesamt: 18,593
