Zum Hauptinhalt wechseln
Lenovo Yoga C930-13IKB Hinge Assembly Replacement
Was du brauchst
  1. Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 2, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 2, Bild 2 von 2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 3, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 3, Bild 2 von 2
    • Carefully lift the cover off with your hands.
  4. Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Battery: Schritt 4, Bild 1 von 3 Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Battery: Schritt 4, Bild 2 von 3 Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Battery: Schritt 4, Bild 3 von 3
    • Unplug the battery from the motherboard by pinching the cables with your fingers and tugging out with force.
    • Use the spudger for assistance.
  5. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the four 3mm screws with a Phillips screwdriver.
  6. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 6, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 6, Bild 2 von 2
    • The battery is still held in place with two stretch-release adhesive strips, similar to ones found in an iPhone.
    • Use your fingers to pry up the clear plastic pull-tab for one of the stretch release adhesives.
    • Grasp the pull-tab and slowly pull away from the battery at a shallow angle. The adhesive strip will stretch to many times its length and slowly release from underneath the battery.
    • Repeat the procedure for the second strip on the opposite side of the battery.
    • Be careful not to bend the battery. Breaking the battery is dangerous.
    • Remove the battery with your hands.
  7. Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Coolant Fans: Schritt 7, Bild 1 von 1
    • Remove the four 3 mm Phillips #0 screws from the fan assembly.
  8. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 8, Bild 1 von 1
    • Remove the four 2 mm Phillips #00 screws from the fans themselves.
  9. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 9, Bild 1 von 1
    • Unscrew the three 3 mm Phillips #0 screws on the heatsink.
  10. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 10, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 10, Bild 2 von 2
    • Use a plastic opening tool to remove the two small, white power cable connectors for each of the two fans.
  11. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 11, Bild 1 von 1
    • Gently lift the fan assembly out of the laptop.
    • Be sure to clean and reapply thermal paste to the heatsink during reassembly.
  12. Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Motherboard: Schritt 12, Bild 1 von 3 Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Motherboard: Schritt 12, Bild 2 von 3 Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Motherboard: Schritt 12, Bild 3 von 3
    • Using the Halberd Spudger, gently lift the black tab on top of each of the five ZIF connectors for the ribbon cables. Then pull the cables out from the connectors.
  13. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 13, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 13, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using the reverse tweezers, gently pull out the small black cable towards the top right of the motherboard.
  14. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 14, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 14, Bild 2 von 2
    • Using two plastic opening tools gently unplug the white speaker cable connector from the bottom left of the motherboard.
  15. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 15, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 15, Bild 2 von 2
    • Using the plastic opening tool, gently pry up on the metal tabs of the two display cables to remove the cables from the top right corner of the motherboard.
  16. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 16, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 16, Bild 2 von 2
    • Remove the fourteen 3 mm Phillips #00 screws that hold in the motherboard.
  17. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 17, Bild 1 von 1
    • While gently grasping each side of the motherboard, carefully lift the assembly out.
  18. Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Display: Schritt 18, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Display: Schritt 18, Bild 2 von 2
    • Using a halberd spudger, gently lift up the metal bezel that lines the lower edge of the display.
  19. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 19, Bild 1 von 1
    • Remove the ten 3 mm screws along the bottom edge of the display with a Phillips #00 screwdriver.
  20. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 20, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 20, Bild 2 von 2
    • Gently wedge two opening picks underneath the display.
    • Slowly work the opening picks around the display.
    • Add opening picks as needed to keep display separated from the frame.
    • Use caution if dealing with broken glass.
    • The iFixit suction cup tool can be used to add some extra leverage to the mix when removing the display.
  21. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 21, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 21, Bild 2 von 2
    • Gently flip the display assembly to rest on top of the keyboard.
  22. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 22, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 22, Bild 2 von 2
    • Use the halberd spudger to lift the locking tab of the ZIF connector holding the black ribbon cable that runs vertically across the display.
    • Pull out the black ribbon cable from the connector.
  23. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 23, Bild 1 von 3 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 23, Bild 2 von 3 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 23, Bild 3 von 3
    • Use the halberd spudger to lift the latch on the ZIF connector of the horizontal black ribbon cable.
    • Pull out the horizontal black ribbon cable from the connector.
    • Gently pull the rest of the horizontal black ribbon cable from the back of the display.
  24. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 24, Bild 1 von 3 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 24, Bild 2 von 3 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 24, Bild 3 von 3
    • Use the halberd spudger to flip the metal latch of the display cable up.
    • Using the halberd spudger, gently pull the connector out of the display.
  25. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 25, Bild 1 von 1
    • Gently lift the display away from the laptop frame.
  26. Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Hinge Assembly: Schritt 26, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement, Hinge Assembly: Schritt 26, Bild 2 von 2
    • Remove the eight 3 mm screws from the hinge attachments on the back cover using the Phillips #00 screwdriver.
    • Carefully detach the hinge assembly connectors from the LCD cover to detach it from the back cover.
  27. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 27, Bild 1 von 3 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 27, Bild 2 von 3 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 27, Bild 3 von 3
    Kaufen
    • Using a Phillips #00 screwdriver, remove the two 3 mm screws from the hinge attachment on the LCD cover.
    • Detach the two hinge retention brackets using the angled ESD tweezers.
  28. Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 28, Bild 1 von 2 Lenovo Yoga C930-13IKB Hinge Assembly Replacement: Schritt 28, Bild 2 von 2
    • Using a Phillips #00 screwdriver remove the six 3 mm screws from the corners of the LCD cover.
    • Carefully lift the hinge assembly, detaching it from the LCD cover.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 43
Insgesamt: 1,000
