Zum Hauptinhalt wechseln
MSI GT72 2QE Dominator Pro Battery Replacement
Was du brauchst
  1. MSI GT72 2QE Dominator Pro Battery Replacement, Battery: Schritt 1, Bild 1 von 2 MSI GT72 2QE Dominator Pro Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Use a Phillips screwdriver to remove the seven 6mm screws from the bottom of the laptop.
    • Lift and remove the bottom case off of the laptop.
  2. MSI GT72 2QE Dominator Pro Battery Replacement: Schritt 2, Bild 1 von 2 MSI GT72 2QE Dominator Pro Battery Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove one 4 mm screw and one 10 mm screw from each fan.
    • The 10mm fan screw won't actually come out, as it is attached with rubber piece to fan. Unscrewing it from the lower case will allow for removal, though.
    • Unplug both fans by gently disconnecting the fan connector from its motherboard socket. If you have trouble, gently wiggle the connector to loosen it.
  3. MSI GT72 2QE Dominator Pro Battery Replacement: Schritt 3, Bild 1 von 1
    • Unplug the SATA cable and remove the hard drive.
    • Make sure to pull cable straight out in order to ensure it stays intact.
  4. MSI GT72 2QE Dominator Pro Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove two 6mm Phillips #0 screws and remove the M.2 SSDs.
    • Make sure you pull SSD straight out so it doesn't get damaged.
  5. MSI GT72 2QE Dominator Pro Battery Replacement: Schritt 5, Bild 1 von 1
    • Unplug both red and black speaker cables. Pull straight out so the connectors aren't damaged.
    • Disconnect both these cables carefully by lifting the pressure tabs then gently pulling.
  6. MSI GT72 2QE Dominator Pro Battery Replacement: Schritt 6, Bild 1 von 1
    • Unplug the battery cable.
    • Pull straight up so as not to damage pins.
  7. MSI GT72 2QE Dominator Pro Battery Replacement: Schritt 7, Bild 1 von 1
    • Remove 15 5mm Phillips #0 screws and remove inner case.
    • Case may take some force to remove, but don't apply excessive force or you risk breaking the plastic connector tabs.
  8. MSI GT72 2QE Dominator Pro Battery Replacement: Schritt 8, Bild 1 von 1
    • Use a card or other flat object to lift and remove the battery from the housing.
    • Be extremely careful removing the battery. If punctured, hazardous chemicals can be released, or the battery could catch fire or even explode.
  9. MSI GT72 2QE Dominator Pro Battery Replacement: Schritt 9, Bild 1 von 1
    • Replace the battery with a 11.1V, 7500mAh Li-ion battery, MSI part number: BTY-L77 or equivalent.
    • Run MSI Battery Calibration to make sure the firmware can see the new batteries cycle high low voltages.
Abschluss
29 weitere Nutzer:innen haben diese Anleitung absolviert.
Kevin Shipp
950 Reputation
1 Anleitung geschrieben
Cal Poly, Team S17-G2, Banghart Spring 2017 Mitglied von Cal Poly, Team S17-G2, Banghart Spring 2017
CPSU-BANGHART-S17S17G2
5 Mitglieder
7 Anleitungen geschrieben
17 Kommentare
Hi,
on the steep 7, you forgot a screw : just above the orange part of the heat sink.
great guide otherwise :D
Assombrance Anderson - Antwort
And another one near the bass speaker
Did it but I was left with one screw. Have no idea where it goes. But hey battery works and not complaining.
Andres Estrin - Antwort
Anyone know where to find a GT72 Dominator battery?
Hunter Gronkowski - Antwort
I bought mine here: http://www.fr-batterie.com/
Thanks for this tutorial!
I used it to replace my GT72 2QD Dominator battery. It’s almost the same (yet, not a piece of cake).
Cameron -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 35
Letzte 30 Tage: 242
Insgesamt: 48,497
