Zum Hauptinhalt wechseln
MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement
Was du brauchst
  1. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
  2. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement, RAM Shield: Schritt 2, Bild 1 von 1
    • Remove the three identical Phillips screws from the memory door.
  3. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 3, Bild 1 von 1
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
  4. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement, Upper Case: Schritt 4, Bild 1 von 1
    • Remove the two 2.8 mm Phillips screws in the battery compartment near the latch.
  5. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 5, Bild 1 von 1
    • Remove the following 6 screws:
    • Two 10 mm T6 Torx screws on either side of the RAM slot.
    • Four 14.5 mm Phillips screws along the hinge.
  6. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 6, Bild 1 von 1
    • Remove the four 3.2 mm Phillips screws on the port side of the computer.
  7. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 7, Bild 1 von 1
    • Rotate the computer 90 degrees and remove the two 3.2 mm Phillips screws from the rear of the computer.
  8. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 8, Bild 1 von 1
    • Rotate the computer 90 degrees again and remove the four 3.2 mm Phillips screws from the side of the computer.
  9. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 9, Bild 1 von 1
    • Do not yank the upper case off quickly. The case is attached to the logic board via a ribbon cable.
    • Lift up at the rear of the case and work your fingers along the sides, freeing the case as you go. Once you have freed the sides, you may need to rock the case up and down to free the front of the upper case (there are some hidden plastic clips that need to be clicked off).
  10. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the trackpad and keyboard ribbon cable from the logic board, removing tape as necessary.
    • Remove the upper case.
  11. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement, Optical Drive: Schritt 11, Bild 1 von 1
    • Disconnect the orange SuperDrive ribbon cable from the logic board, removing tape as necessary.
  12. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 12, Bild 1 von 1
    • Remove the following 4 screws:
    • Two 3.3 mm silver Phillips screws on either side of the SuperDrive.
    • One 4.7 mm silver T6 Torx screw from the top left corner of the drive
    • One 6.2 mm black Phillips screw at the top right corner of the drive.
  13. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 13, Bild 1 von 1
    • Lift the optical drive up and out of the computer.
  14. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement, Logic Board: Schritt 14, Bild 1 von 1
    • Disconnect the hard drive and ExpressCard connectors from the left side of the logic board.
  15. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 15, Bild 1 von 1
    • Disconnect the iSight and display data cables from the logic board by sliding the cables out of their connectors, removing tape as necessary.
  16. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 16, Bild 1 von 1
    • Disconnect the eight indicated connectors by placing a spudger beneath each cable and lifting up.
  17. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 17, Bild 1 von 1
    • Remove the silver T6 Torx screw securing the ground loop in the display data cable to the casing.
  18. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 18, Bild 1 von 1
    • Remove the single T6 Torx screw securing the clear plastic shield over the right ambient light sensor.
    • Lift the clear plastic shield off the right ambient light sensor.
  19. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 19, Bild 1 von 1
    • Peel up the orange Kapton tape securing the right thermal sensor cable to the logic board.
  20. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 20, Bild 1 von 1
    • Remove the following 15 screws:
    • One 4.4 mm black Phillips screw to the right of the ram slot.
    • Eight 4.7 mm silver T6 Torx screws securing the logic board to the lower case.
    • One 6.2 mm black T6 Torx screw on the right side of the left fan.
    • Five 9.4 mm silver T6 Torx screws securing the left and right fans.
  21. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 21, Bild 1 von 1
    • Hold the logic board down with one hand and use your other hand to lift the left fan up from its housing. There is a piece of black tape securing the fan to the heat sink. Carefully peel this tape up from the heat sink as you lift the fan up.
    • Place the fan above the Airport card. It is not necessary to remove the fan from the computer entirely.
  22. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 22, Bild 1 von 1
    • Lift the right fan up and carefully peel up the tape securing the fan to the heat sink as you go.
    • Remove the right fan from the computer.
  23. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 23, Bild 1 von 1
    • Lift up the left side of the logic board and disconnect the gray and black power cable from the bottom of the board.
  24. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement: Schritt 24, Bild 1 von 1
    • Grasp the logic board at the left side and at the thin section, and rotate the logic board out of the lower case.
    • To properly reassemble your MacBook Pro, you'll have to clean off and replace the old thermal compound. Use our Applying Thermal Paste Guide to prepare the processor and heat sink surfaces.
  25. MacBook Pro 15" Core 2 Duo Model A1211 Logic Board Replacement, Logic Board: Schritt 25, Bild 1 von 1
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • Pull the chip directly out from its connector.
    • If there are two RAM chips installed, repeat the above procedure for the second chip.
Abschluss
48 weitere Nutzer:innen haben diese Anleitung absolviert.
iRobot
1 Reputation
636 Anleitungen geschrieben
7 Kommentare
When putting the card back in place, take care that the thermal sensor cables coming from the lower case be over the card, and that the black spacers near the screen be in place.
Claude Papoin - Antwort
As well as the battery cable !
I went to Lowe's and got a can of dusting air and cleaned the whole bottom case before putting it back together, it was full of dust. It cleaned it up pretty good.
Matt - Antwort
Will i lose any of my files after doing this procedure?
Eugene Zabala - Antwort
Great guide!! Thank you. I completed the whole process in around one hour.
glovalvo - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 35
Insgesamt: 71,895
