Einleitung
Use this guide to replace the front-facing camera on your Nexus 9.
Was du brauchst
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Use a spudger to disconnect the front-facing camera ZIF connector.
Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
