Zum Hauptinhalt wechseln
Nintendo Wii mini Disc Drive Replacement
Was du brauchst
  1. Nintendo Wii mini Disc Drive Replacement, Unscrew the Bottom: Schritt 1, Bild 1 von 2 Nintendo Wii mini Disc Drive Replacement, Unscrew the Bottom: Schritt 1, Bild 2 von 2
    • Remove the two rubber feet at the back of the console to reveal the hidden screws.
    • Remove the four 6mm Phillips #0 screws.
  2. Nintendo Wii mini Disc Drive Replacement, Remove the Cover: Schritt 2, Bild 1 von 3 Nintendo Wii mini Disc Drive Replacement, Remove the Cover: Schritt 2, Bild 2 von 3 Nintendo Wii mini Disc Drive Replacement, Remove the Cover: Schritt 2, Bild 3 von 3
    • Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
    • Gently lift the top piece of the console and set it aside.
  3. Nintendo Wii mini Disc Drive Replacement, Unscrew the Fan: Schritt 3, Bild 1 von 2 Nintendo Wii mini Disc Drive Replacement, Unscrew the Fan: Schritt 3, Bild 2 von 2
    • Turn the Wii mini around so that the back of the device is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
    • You may need to use tweezers to pull out the screws once they are loosened.
  4. Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: Schritt 4, Bild 1 von 3 Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: Schritt 4, Bild 2 von 3 Nintendo Wii mini Disc Drive Replacement, Detach the Fan Connector: Schritt 4, Bild 3 von 3
    • Using your fingers, gently pull the top of the pin connector straight up to detach the fan from the console.
    • Do not wiggle the connector or cable while removing. This may cause the connector to come loose
    • Remove the fan piece and set it aside.
  5. Nintendo Wii mini Disc Drive Replacement, Power Board: Schritt 5, Bild 1 von 3 Nintendo Wii mini Disc Drive Replacement, Power Board: Schritt 5, Bild 2 von 3 Nintendo Wii mini Disc Drive Replacement, Power Board: Schritt 5, Bild 3 von 3
    • Using your fingers, slide out the blue ribbon cable from the the top of the power board.
    • Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
  6. Nintendo Wii mini Disc Drive Replacement: Schritt 6, Bild 1 von 2 Nintendo Wii mini Disc Drive Replacement: Schritt 6, Bild 2 von 2
    • Using your fingers, gently pull the pin connector to disconnect the power board from the disc drive.
  7. Nintendo Wii mini Disc Drive Replacement: Schritt 7, Bild 1 von 2 Nintendo Wii mini Disc Drive Replacement: Schritt 7, Bild 2 von 2
    • Lift the power board from the console and set it aside.
  8. Nintendo Wii mini Disc Drive Replacement, Disc Drive: Schritt 8, Bild 1 von 2 Nintendo Wii mini Disc Drive Replacement, Disc Drive: Schritt 8, Bild 2 von 2
    • Using a Phillips #0 Screwdriver, unscrew the four 6mm screws.
  9. Nintendo Wii mini Disc Drive Replacement: Schritt 9, Bild 1 von 2 Nintendo Wii mini Disc Drive Replacement: Schritt 9, Bild 2 von 2
    • Lift the disc drive out of the console and set it aside.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
UWT Liner: Group 5 Mitglied von UWT Liner: Group 5
Community
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 24
Letzte 30 Tage: 62
Insgesamt: 4,342
