Zum Hauptinhalt wechseln
Diese Übersetzung enthält möglicherweise noch nicht die neuesten Änderungen der Original-Anleitung. Hilf mit, die Übersetzung zu aktualisieren oder sieh dir die Original-Anleitung an.
OnePlus 7 Pro Display austauschen
Was du brauchst
Abschluss
Um das Gerät wieder zusammenzubauen, einfach der Anleitung rüchwärts folgen.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
en de
4%
Hier starten ›
Selena
2.668 Reputation
14 Anleitungen geschrieben
11 Kommentare
So I have a friend that owns this phone and has had the screen replaced, there is however some misalignment of the screen and frame on her phone in the form of a very obvious crack between the two, the two surfaces are also not flush. Could someone in theory have improperly repaired the phone by separating the screen from the frame and gluing a new one in place?
Thank you and have a nice day.
Clayton Lawliss - Antwort
No that is due to the frame being bent, if it is bent the screen will not sit properly and it is a difficult task to un bend a frame but it is possible.
Zach Benson -
Is it possible to replace just the top glass if the rest of the screen is intact? It's got surface cracks both front and back.
MJ Mulenga III - Antwort
No don't and I mean DONT go that route the glass or whatever seems cheaper but the repair of separating them is next to impossible. Its like trying to take a part two potatoe chips that have been glued together and in the process not breaking either. Get a screen replacement.
Zach Benson -
Absolutely none of this is necessary as they don’t sell the screen with the frame. If you’re unlucky like me you’ll get the entire phone apart and then it will tell you to reassemble parts onto screen WITH frame.
Joel Tool - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 90
Letzte 30 Tage: 353
Insgesamt: 15,710
