Zum Hauptinhalt wechseln
PlayStation Vita Rear Camera Replacement
Was du brauchst
  1. PlayStation Vita Rear Camera Replacement, Case Separation: Schritt 1, Bild 1 von 2 PlayStation Vita Rear Camera Replacement, Case Separation: Schritt 1, Bild 2 von 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Rear Camera Replacement: Schritt 2, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 2, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 2, Bild 3 von 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Rear Camera Replacement: Schritt 3, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Rear Camera Replacement: Schritt 4, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 4, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 4, Bild 3 von 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Rear Camera Replacement: Schritt 5, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 5, Bild 2 von 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Rear Camera Replacement: Schritt 6, Bild 1 von 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Rear Camera Replacement: Schritt 7, Bild 1 von 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Rear Camera Replacement: Schritt 8, Bild 1 von 1
    • Separate the front and rear cases.
  9. PlayStation Vita Rear Camera Replacement, Wireless Card: Schritt 9, Bild 1 von 3 PlayStation Vita Rear Camera Replacement, Wireless Card: Schritt 9, Bild 2 von 3 PlayStation Vita Rear Camera Replacement, Wireless Card: Schritt 9, Bild 3 von 3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Rear Camera Replacement: Schritt 10, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 10, Bild 2 von 2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Rear Camera Replacement: Schritt 11, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 11, Bild 2 von 2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Rear Camera Replacement, Right Shoulder Button: Schritt 12, Bild 1 von 3 PlayStation Vita Rear Camera Replacement, Right Shoulder Button: Schritt 12, Bild 2 von 3 PlayStation Vita Rear Camera Replacement, Right Shoulder Button: Schritt 12, Bild 3 von 3
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Rear Camera Replacement: Schritt 13, Bild 1 von 1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Rear Camera Replacement: Schritt 14, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 14, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 14, Bild 3 von 3
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Rear Camera Replacement: Schritt 15, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 15, Bild 2 von 2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
  16. PlayStation Vita Rear Camera Replacement, Right Button Board: Schritt 16, Bild 1 von 2 PlayStation Vita Rear Camera Replacement, Right Button Board: Schritt 16, Bild 2 von 2
    • Using the pointy end of a spudger, detach the antenna cable on the right button board.
    • Remove the antenna cable.
  17. PlayStation Vita Rear Camera Replacement: Schritt 17, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 17, Bild 2 von 2
    • Using a spudger, pry up and release the ZIF socket on the right button board.
    • Gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  18. PlayStation Vita Rear Camera Replacement: Schritt 18, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 18, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 18, Bild 3 von 3
    • Release the tab on the small flex cable socket by prying up the tab with a spudger.
    • Using tweezers, gently pull the flex cable out of the socket. Rest the flex cable out of the way.
  19. PlayStation Vita Rear Camera Replacement: Schritt 19, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 19, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 19, Bild 3 von 3
    • Remove the two 5.0mm Phillips #00 screws from the metal bracket securing the right button board to the motherboard.
    • Remove the metal bracket, using a spudger as necessary to lift it out.
  20. PlayStation Vita Rear Camera Replacement: Schritt 20, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 20, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 20, Bild 3 von 3
    • Use a spudger to free the right button board by prying up from the bottom right corner of board.
    • Gently lift the right button board out.
  21. PlayStation Vita Rear Camera Replacement, Left Shoulder Button: Schritt 21, Bild 1 von 3 PlayStation Vita Rear Camera Replacement, Left Shoulder Button: Schritt 21, Bild 2 von 3 PlayStation Vita Rear Camera Replacement, Left Shoulder Button: Schritt 21, Bild 3 von 3
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  22. PlayStation Vita Rear Camera Replacement: Schritt 22, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 22, Bild 2 von 2
    • Remove the translucent, plastic left shoulder button cover.
  23. PlayStation Vita Rear Camera Replacement: Schritt 23, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 23, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 23, Bild 3 von 3
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
  24. PlayStation Vita Rear Camera Replacement: Schritt 24, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 24, Bild 2 von 2
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
  25. PlayStation Vita Rear Camera Replacement, Left Button Board: Schritt 25, Bild 1 von 2 PlayStation Vita Rear Camera Replacement, Left Button Board: Schritt 25, Bild 2 von 2
    • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
    • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
  26. PlayStation Vita Rear Camera Replacement: Schritt 26, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 26, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 26, Bild 3 von 3
    • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
    • Lift the SIM card reader off the back casing assembly.
  27. PlayStation Vita Rear Camera Replacement: Schritt 27, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 27, Bild 2 von 2
    • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
    • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
  28. PlayStation Vita Rear Camera Replacement: Schritt 28, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 28, Bild 2 von 2
    • Use a spudger to lift up the tab on the large ZIF socket.
    • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
  29. PlayStation Vita Rear Camera Replacement: Schritt 29, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 29, Bild 2 von 2
    • Disconnect the white Wi-Fi antenna cable with a spudger.
    • Remove the Wi-Fi antenna cable.
  30. PlayStation Vita Rear Camera Replacement: Schritt 30, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 30, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 30, Bild 3 von 3
    • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
    • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
    • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
  31. PlayStation Vita Rear Camera Replacement: Schritt 31, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 31, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 31, Bild 3 von 3
    • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
  32. PlayStation Vita Rear Camera Replacement, Rear Camera: Schritt 32, Bild 1 von 2 PlayStation Vita Rear Camera Replacement, Rear Camera: Schritt 32, Bild 2 von 2
    • Using the pointy end of a spudger, pry up and release the GPS antenna cable from the motherboard.
    • Remove the GPS antenna cable.
  33. PlayStation Vita Rear Camera Replacement: Schritt 33, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 33, Bild 2 von 2
    • Release the camera flex cable socket by prying up on the tab with a spudger.
  34. PlayStation Vita Rear Camera Replacement: Schritt 34, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 34, Bild 2 von 2
    • Using a spudger, gently pry up on the camera.
    • Work your way under the camera and along the camera flex cable, using the spudger to peel away the adhesive, freeing the camera.
  35. PlayStation Vita Rear Camera Replacement: Schritt 35, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 35, Bild 2 von 2
    • Carefully lift and remove the camera, sliding the flex cable out of the open connector socket.
  36. PlayStation Vita Rear Camera Replacement: Schritt 36, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 36, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the 6.3mm screw beneath the camera.
    • Lift and remove the metal camera bracket.
  37. PlayStation Vita Rear Camera Replacement: Schritt 37, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 37, Bild 2 von 2
    • With the help of a spudger, lift and release the tab on the blue flex cable socket.
  38. PlayStation Vita Rear Camera Replacement: Schritt 38, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 38, Bild 2 von 2
    • Using tweezers, gently pull the blue power flex cable out of the socket, and rest it out of the way.
  39. PlayStation Vita Rear Camera Replacement: Schritt 39, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the two pink, 4.4mm screws securing the motherboard.
  40. PlayStation Vita Rear Camera Replacement: Schritt 40, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 40, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 40, Bild 3 von 3
    • Gently peel the rubber tab of the game port cover off the plastic casing pins.
    • Remove the game port cover.
  41. PlayStation Vita Rear Camera Replacement: Schritt 41, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 41, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 41, Bild 3 von 3
    • Gently peel the rubber tab of the accessory port cover off the plastic casing pins.
    • Remove the accessory port cover.
  42. PlayStation Vita Rear Camera Replacement: Schritt 42, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 42, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 42, Bild 3 von 3
    • Starting at the upper right hand corner, use a spudger to gently lift the motherboard out of the casing assembly.
    • The motherboard is still attached to the casing by a connector on the back of the motherboard. Do not pull the motherboard all the way out, or you may damage the connector.
  43. PlayStation Vita Rear Camera Replacement: Schritt 43, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 43, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 43, Bild 3 von 3
    • Lift the motherboard out and identify the OLED connector still attaching the motherboard to the casing.
    • Holding the Vita on its side, use a spudger to gently pry off the OLED connector from the motherboard.
    • Be sure to hold the motherboard while you release the connector as this will free the motherboard. If you are not holding the motherboard, it will fall.
  44. PlayStation Vita Rear Camera Replacement: Schritt 44, Bild 1 von 1
    • Completely separate the motherboard from the case. Set the case aside.
  45. PlayStation Vita Rear Camera Replacement: Schritt 45, Bild 1 von 2 PlayStation Vita Rear Camera Replacement: Schritt 45, Bild 2 von 2
    • Flip the motherboard over so that the rear camera is facing you on the right.
    • Release the rear camera flex cable socket by prying up on the tab with a spudger. Leave the socket open.
  46. PlayStation Vita Rear Camera Replacement: Schritt 46, Bild 1 von 3 PlayStation Vita Rear Camera Replacement: Schritt 46, Bild 2 von 3 PlayStation Vita Rear Camera Replacement: Schritt 46, Bild 3 von 3
    • Gently pull the rear camera out of the flex cable socket.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Brittany McCrigler
89.017 Reputation
131 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.820 Anleitungen geschrieben
Ein Kommentar
This is not it's rear-facing camera though - it is it's front-facing camera.
iFixOmaha LLC - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 5,324
