Zum Hauptinhalt wechseln
Samsung Chromebook 3 Display Replacement
Was du brauchst
  1. Samsung Chromebook 3 Display Replacement, Bottom Case: Schritt 1, Bild 1 von 2 Samsung Chromebook 3 Display Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Display Replacement: Schritt 2, Bild 1 von 3 Samsung Chromebook 3 Display Replacement: Schritt 2, Bild 2 von 3 Samsung Chromebook 3 Display Replacement: Schritt 2, Bild 3 von 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Display Replacement: Schritt 3, Bild 1 von 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Display Replacement, Battery: Schritt 4, Bild 1 von 2 Samsung Chromebook 3 Display Replacement, Battery: Schritt 4, Bild 2 von 2
    • Locate the battery and remove the four 4.6mm screws at the corners which attach it to case using a Phillips #00 screwdriver.
  5. Samsung Chromebook 3 Display Replacement: Schritt 5, Bild 1 von 2 Samsung Chromebook 3 Display Replacement: Schritt 5, Bild 2 von 2
    • Use a spudger to gently pry the power cable cord upwards from the motherboard.
  6. Samsung Chromebook 3 Display Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery up and out from the case.
  7. Samsung Chromebook 3 Display Replacement, Display: Schritt 7, Bild 1 von 3 Samsung Chromebook 3 Display Replacement, Display: Schritt 7, Bild 2 von 3 Samsung Chromebook 3 Display Replacement, Display: Schritt 7, Bild 3 von 3
    • Disengage the gold connector joining the display and motherboard by flipping up the hinge with a spudger and gently disconnecting it with a spudger or your fingers.
  8. Samsung Chromebook 3 Display Replacement: Schritt 8, Bild 1 von 3 Samsung Chromebook 3 Display Replacement: Schritt 8, Bild 2 von 3 Samsung Chromebook 3 Display Replacement: Schritt 8, Bild 3 von 3
    • Next disconnect the small coaxial cables from the wireless chip on the daughterboard by prying upwards with a spudger.
  9. Samsung Chromebook 3 Display Replacement: Schritt 9, Bild 1 von 2 Samsung Chromebook 3 Display Replacement: Schritt 9, Bild 2 von 2
    • Flip up at least one side of the adhesive tape holding the coaxial cables in place. When the display is removed, the cables are coming with it!
  10. Samsung Chromebook 3 Display Replacement: Schritt 10, Bild 1 von 2 Samsung Chromebook 3 Display Replacement: Schritt 10, Bild 2 von 2
    • Finally, remove the four 4.6mm screws from the display mounts using a Phillips #00 screwdriver.
    • It might be easier to open the laptop before removing these screws as the display will only come off while in the open position.
  11. Samsung Chromebook 3 Display Replacement: Schritt 11, Bild 1 von 1
    • Open the laptop and remove the display.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Austin Blakely
19.524 Reputation
53 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
16.832 Anleitungen geschrieben
3 Kommentare
Any idea as to what kind of connector the display has to the motherboard? Or how many pins? Trying to tear down the display and see if I can use it as an extra monitor.
Sam Rall - Antwort
It looks like there are 40 pins on the display connector. I’m not sure what it would be called or if it’s any kind of standard. If you do manage to convert the display to an extra monitor, you should definitely let us know though!
Austin Blakely -
Great guide - my 12 year old son was able to get through it with a little help from me. Nice work.
smo2 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 1,497
