Zum Hauptinhalt wechseln
Samsung Chromebook 3 Speakers Replacement
Was du brauchst
  1. Samsung Chromebook 3 Speakers Replacement, Bottom Case: Schritt 1, Bild 1 von 2 Samsung Chromebook 3 Speakers Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Place the Chromebook face down so that the bottom case is exposed.
    • Using a Phillips #00 screwdriver, remove nine 4.6mm screws from the back casing.
  2. Samsung Chromebook 3 Speakers Replacement: Schritt 2, Bild 1 von 3 Samsung Chromebook 3 Speakers Replacement: Schritt 2, Bild 2 von 3 Samsung Chromebook 3 Speakers Replacement: Schritt 2, Bild 3 von 3
    • Use a iFixit opening tool to gently pry the case up from the vent on the hinge side of the Chromebook.
    • You should hear a popping sound as the connectors disengage inside the case.
  3. Samsung Chromebook 3 Speakers Replacement: Schritt 3, Bild 1 von 1
    • Lift the case up and off the device
  4. Samsung Chromebook 3 Speakers Replacement, Speakers: Schritt 4, Bild 1 von 2 Samsung Chromebook 3 Speakers Replacement, Speakers: Schritt 4, Bild 2 von 2
    • Disconnect the battery from the motherboard by prying upwards on the cable connector with a spudger.
  5. Samsung Chromebook 3 Speakers Replacement: Schritt 5, Bild 1 von 3 Samsung Chromebook 3 Speakers Replacement: Schritt 5, Bild 2 von 3 Samsung Chromebook 3 Speakers Replacement: Schritt 5, Bild 3 von 3
    • Remove one 4.9mm silver screw from each speaker with a Phillips #00 screwdriver.
  6. Samsung Chromebook 3 Speakers Replacement: Schritt 6, Bild 1 von 3 Samsung Chromebook 3 Speakers Replacement: Schritt 6, Bild 2 von 3 Samsung Chromebook 3 Speakers Replacement: Schritt 6, Bild 3 von 3
    • Use a plastic spudger to gently coax the cable connecter sideways from the motherboard and the left speaker. When disconnected, remove speaker.
  7. Samsung Chromebook 3 Speakers Replacement: Schritt 7, Bild 1 von 3 Samsung Chromebook 3 Speakers Replacement: Schritt 7, Bild 2 von 3 Samsung Chromebook 3 Speakers Replacement: Schritt 7, Bild 3 von 3
    • Use a plastic spudger to gently disconnect the cable connecter from the daughterboard and the right speaker. Remove the speaker.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sarah Westberg
23.194 Reputation
70 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
135 Mitglieder
17.153 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 523
