Zum Hauptinhalt wechseln
Samsung Galaxy S4 Active Midframe Replacement
Was du brauchst
  1. Samsung Galaxy S4 Active Midframe Replacement, Rear Case: Schritt 1, Bild 1 von 2 Samsung Galaxy S4 Active Midframe Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  2. Samsung Galaxy S4 Active Midframe Replacement, MicroSD Card: Schritt 2, Bild 1 von 1
    • Use a plastic opening tool, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
  3. Samsung Galaxy S4 Active Midframe Replacement, Battery: Schritt 3, Bild 1 von 1
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward to remove it.
  4. Samsung Galaxy S4 Active Midframe Replacement, SIM Card: Schritt 4, Bild 1 von 1
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
  5. Samsung Galaxy S4 Active Midframe Replacement, Midframe: Schritt 5, Bild 1 von 1
    • Use the tip of a spudger to remove the four metallic pads located in each corner of the device.
    • Using a Phillips #00 screwdriver, remove the 12 screws connecting the midframe to the device.
  6. Samsung Galaxy S4 Active Midframe Replacement: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool to pry around the entire edge of the midframe now to release it from the front case.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Geoff Wacker
89.996 Reputation
89 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 16
Insgesamt: 3,437
