Zum Hauptinhalt wechseln
Samsung RF28R7201SG Refrigerator Door Sensors Replacement
Was du brauchst
  1. Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Remove the hinge cover: Schritt 2, Bild 1 von 1
    • Use a Phillips screwdriver to remove the three 18.5 mm-long screws securing the hinge cover on the top of the refrigerator.
  3. Samsung RF28R7201SG Refrigerator Door Sensors Replacement: Schritt 3, Bild 1 von 1
    • Lift the edges of the hinge cover to loosen it from the refrigerator.
    • Don't try to fully remove the cover, as it's still attached to the refrigerator by a few cables.
    • Flip the hinge cover over to access the cables underneath.
  4. Samsung RF28R7201SG Refrigerator Door Sensors Replacement: Schritt 4, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Door Sensors Replacement: Schritt 4, Bild 2 von 2
    • Use your fingers to squeeze and disconnect the blue wire connector.
    • Use your fingers to squeeze and disconnect the white wire connector.
  5. Samsung RF28R7201SG Refrigerator Door Sensors Replacement: Schritt 5, Bild 1 von 1
    • Remove the hinge cover.
  6. Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Sensor information: Schritt 6, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Sensor information: Schritt 6, Bild 2 von 2
    • The hinge cover has two door sensors:
    • The left door sensor
    • The left door sensor connector
    • The right door sensor
    • The right door sensor connector
    • Depending on your situation, you may need to replace either or both sensors.
  7. Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Remove the sensor: Schritt 7, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Door Sensors Replacement, Remove the sensor: Schritt 7, Bild 2 von 2
    • Use your fingers to squeeze and disconnect the sensor cable connector.
  8. Samsung RF28R7201SG Refrigerator Door Sensors Replacement: Schritt 8, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Door Sensors Replacement: Schritt 8, Bild 2 von 2
    • Use a spudger or a flathead screwdriver to pry the sensor out of its retaining clips.
  9. Samsung RF28R7201SG Refrigerator Door Sensors Replacement: Schritt 9, Bild 1 von 1
    • Remove the door sensor.
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.927 Reputation
88 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
33 Mitglieder
583 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 7
Letzte 30 Tage: 17
Insgesamt: 170
