Zum Hauptinhalt wechseln
Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement
Was du brauchst
  1. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unplug your refrigerator: Schritt 1, Bild 1 von 1
    • Unplug your refrigerator before you begin your repair.
  2. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: Schritt 2, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Open the refrigerator doors: Schritt 2, Bild 2 von 2
    • Open both French doors for the refrigerator compartment.
  3. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: Schritt 3, Bild 1 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: Schritt 3, Bild 2 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the ice tray: Schritt 3, Bild 3 von 3
    • Pull the ice tray straight out of its housing and remove it.
  4. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: Schritt 4, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the cable cover panel: Schritt 4, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 16.5 mm‑long screw securing the cable cover panel.
  5. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: Schritt 5, Bild 1 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: Schritt 5, Bild 2 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the cable cover panel: Schritt 5, Bild 3 von 3
    • Use your fingers to slide the cable cover panel towards the front of the refrigerator to unlatch it.
    • Remove the cable cover panel.
    • During reassembly, make sure this panel clips fully in place, or the ice tray won't slide in properly.
  6. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: Schritt 6, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Disconnect the icemaker harness: Schritt 6, Bild 2 von 2
    • Disconnect the left-most yellow connector:
    • Squeeze the locking tab with the red mark with your fingers
    • Rock the connector gently side to side to disconnect it
    • Use your fingers or a screwdriver to guide the wire harness out of the wall clips.
  7. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Unfasten the air tunnel: Schritt 7, Bild 1 von 1
    • Use a Phillips screwdriver to remove the 16.5 mm-long screw securing the air tunnel flap.
  8. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: Schritt 8, Bild 1 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: Schritt 8, Bild 2 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement, Remove the icemaker assembly: Schritt 8, Bild 3 von 3
    • A plastic clip holds the air tunnel flap in place.
    • Use a flathead screwdriver to pry and loosen the air tunnel flap from the plastic clip.
  9. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 9, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 9, Bild 2 von 2
    • Use your fingers to pull the air tunnel flap down enough to access the internals.
  10. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 10, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 10, Bild 2 von 2
    • Use a flathead screwdriver to gently pry the refrigerant loop down by 1–1.5 cm.
    • During reassembly, use your fingers to push the refrigerant loop back up.
  11. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 11, Bild 1 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 11, Bild 2 von 3 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 11, Bild 3 von 3
    • A plastic clip holds the icemaker in place.
    • Use your fingers to press and release the plastic clip.
    • This clip is stiff and may require substantial force.
  12. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 12, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 12, Bild 2 von 2
    • Pull the front edge of the icemaker assembly down slightly to loosen it.
    • Be careful not to bend the refrigerant loop too much as you pull the front edge, or you'll damage the loop.
    • Carefully slide the icemaker assembly out of its housing.
  13. Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 13, Bild 1 von 2 Samsung RF28R7201SG Refrigerator Icemaker Assembly Replacement: Schritt 13, Bild 2 von 2
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
nicO
15.927 Reputation
88 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
34 Mitglieder
589 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 133
Insgesamt: 674
