Mein Problem
I enjoy hearing my music loud. My MacBook Air not so much - i blew one of the speakers
Meine Reparatur
Repairing was a piece of cake, the guide was perfectly clear I din't have any problems with it.
Mein Rat
nope
Dieser Artikel ist in deinem Land leider nicht verfügbar.
Artikel-Nr: IF108-005-1
9,99 $
Im Angebot
Gebrauchte A-Stock Ware ist in ausgezeichnetem Zustand
Als B-Stock deklarierte Ware hat leichte Gebrauchsspuren
Als C-Stock deklarierte Ware hat starke Gebrauchsspuren, ist aber voll funktionstüchtig
9,99 $
Im Angebot
Nicht auf Lager
So viel haben wir leider nicht auf Lager
Artikelbeschreibung
Beschreibung
Beschreibung
Replace a right speaker in your Late 2010 to Early 2015 MacBook Air 11" laptop and fix issues with sound output.
An aging or malfunctioning speaker may have buzzing noises or cut out unexpectedly. Restore your laptop's sound quality with this replacement part.
Kompatibilität
Kompatibilität
Eigenschaften
Eigenschaften
Kompatibilität
3 weitere Geräte zeigen
3 Geräte ausblenden
Reparaturanleitungen
Schwierigkeitsgrad:
Mittel
Schwierigkeitsgrad:
Mittel
Schwierigkeitsgrad:
Mittel
Schwierigkeitsgrad:
Mittel
Schwierigkeitsgrad:
Mittel
Reparatur-Geschichten
nope
the sound coming out of my mba was terrible. it was broken and i was using external speakers.
Finding the right part from ifixit was great and with the clear how-to instructions it was a cinch. thanks and kudos to you!
May i suggest, that you identify the orientation when you say the "right speaker".
It took me a while to discover that the right speaker will be actually on the left when you open up the MBA because it would be upsidedown.
My right speaker was distorting very badly.
Fantastic. Couldn't have been easier. The tools and guide are fantastic. Replacing the speakers is a pretty simple task when you have the correct tools.
Be very careful when tightening the screws. They are small and somewhat soft and you can strip the heads pretty easily. You don't need as much torque as you think.
Be very careful when tightening the screws. They are small and somewhat soft and you can strip the heads . . .
Right speaker on my MacBook Air blew out when I was using an app to play audio louder than the OS limits... oops.
Super easy. Took all of 10 minutes, maybe? Normally I would have had to do the whole Apple Store repair process; this was so much better, and fun.
Follow the guide that's here well, and you will be set.
Follow the guide that's here well, and yo . . .
I destroyed my Macbook Air Speakers using a little peace of software called BOOM.
I just followed the replacement guide on ifixit and it was super easy.
Nothing to add here
Installed a third party volume boosting app from the App Store on my Macbook Air. Shortly after the right speaker started crackling!
Easy. Followed the instruction guide step by step. You may think you do not need to buy the spudger; don't be fooled. It's an essential tool.
Get the spudger. Make sure you have the correct torx and penta-tool for the screws.
Get the spudger. Make sur . . .
A strange cracking sound started when I watched a movie and after some tests, I've discovered the need of the speaker to be changed.
The repair was fine, I'm happy with the results. The speaker have some kind of glue or tape to help the speaker to be fixed. To remove it need some effort but nothing difficult.
Nothing at all, the guide is excellent.
The repair was fine, I'm happy with the results. The speaker have some kind of glue or tape to help the speaker to be fixed. To remove it need some effort but nothing d . . .
The right speaker sounded awful
This is very easy and takes only 15 minutes
Nothing
Mehr anzeigen
Weniger anzeigen
Kunden kauften auch
Empfohlene Artikel
