Mein Problem
My trackpad was cracked and couldn't click
Meine Reparatur
It went well.
Mein Rat
I suggest using a desk lamp, bright flashlight, or any bright light. I also recommend using a small magnifying glass.
Dieser Artikel ist in deinem Land leider nicht verfügbar.
Artikel-Nr: IF108-054-3
109,99 $
Im Angebot
Gebrauchte A-Stock Ware ist in ausgezeichnetem Zustand
Als B-Stock deklarierte Ware hat leichte Gebrauchsspuren
Als C-Stock deklarierte Ware hat starke Gebrauchsspuren, ist aber voll funktionstüchtig
109,99 $
Im Angebot
Nicht auf Lager
So viel haben wir leider nicht auf Lager
Artikelbeschreibung
Beschreibung
Beschreibung
Replace a damaged trackpad and restore the touch sensitivity of your Mid 2013 to Early 2015 model 11" MacBook Air laptop.
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control. Fix these issues with this replacement part.
Kompatibilität
Kompatibilität
Eigenschaften
Eigenschaften
Kompatibilität
Reparatur-Geschichten
It went well.
When attempting to clean and adjustment the trackpad I ended up breaking the keyboard ribbon cable zif connector - So I ended up having to purchase a new trackpad.
The new trackpad was replaced with out any issues. The zif connector is a bit finicky for attaching both the trackpad ribbon and the keyboard ribbon. My laptop now works great - so I'm happy.
Be really careful when lifting the zif connectors to remove and insert the ribbons. It's very thin plastic and if it breaks you have to replace the entire trackpad. I used the All-new Pro Tech Toolkit, which is awesome. Great tools, great case. Highly recommend this kit - I
The new trackpad was replaced with out any issues. The zif connector is a bit finicky for attaching both the trackpad ribbon and the keyb . . .
Wird oft zusammen gekauft
Empfohlene Artikel
