MacBook Pro (Santa Rosa) Display Components
Grab a toolkit for your MacBook Pro (Santa Rosa) model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Wähle dein MacBook Pro (Santa Rosa) Modell:
Ersatzteile für MacBook Pro (Santa Rosa):
MacBook Pro 15" (Models A1226/A1260) Clutch Cover
Houses the hinges and airport antenna assembly.
MacBook Pro 15" (Models A1226/A1260) Front Display Bezel
Replace a damaged bezel without the cost of a new LCD
MacBook Pro 17" (Models A1151/A1212/A1229) Display Data Cable
Replace a damaged or malfunctioning cable connecting the LCD panel to the logic board.
MacBook Pro 15" (Models A1211/A1226) Airport Antenna Cables
Replace the antenna cables and the assembly that rests inside the antenna cover compatible with the A1211 or A1226 model 15 inch MacBook Pro laptop.
MacBook Pro 15" (Models A1226/A1260) LED Driver Board
LED Driver Board controls the LED backlight.
MacBook Pro 15" (Models A1226/A1260) Inverter/iSight Cable
MacBook Pro 15" (Models A1211/A1226/A1260) Antenna Cover
Replace an antenna cover that houses the AirPort antenna cable assembly within the clutch cover compatible with the model A1211, A1226, A1260 15 inch MacBook Pro laptop.
Geräteinformation
Apple's next version of MacBook Pro includes the Santa Rosa architecture, which results in a faster bus speed and a graphics upgrade. Both the 15" and 17" versions benefit from this overhaul.
These machines can easily be upgraded to a total of 6 GB of memory, using a 4 GB RAM chip and a 2 GB RAM chip. Don't let all the RAM go to waste on a slow hard drive. Max out your hard drive with a whopping 500 GB 7200 RPM SATA hard drive!
Select your screen size above for parts, troubleshooting, and more!
