MacBook Pro 13" Four Thunderbolt Ports 2020 Case Components
Grab a toolkit for your MacBook Pro 13" Four Thunderbolt Ports 2020 model A2251 and fix a broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Ersatzteile für MacBook Pro 13" Four Thunderbolt Ports 2020:
MacBook Pro 13" Retina (Touch Bar, Late 2016-2020) Display Cable Brackets
Replace the brackets that secure the display cable connector to the display daughter board and clamp the middle of the cable to the upper case assembly in a 2016 to 2020 ...
MacBook Pro 13" Retina (Touch Bar, Late 2016-2020) Hinge Covers
Replace the plastic covers for the display hinges.
MacBook Pro 13" (2020) Touch Bar and USB-C Cable Bracket
Replace a bent or missing bracket that secures the touch bar cable and one USB-C cable to the logic board in a 2020 model A2251 or A2289 13" MacBook Pro laptop.
MacBook Pro 13" Retina (Late 2016-2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2020 model 13" MacBook Pro with Retina Display.
MacBook Pro 13" Retina (Touch Bar, Late 2016-2020) Trackpad Cable Bracket
Replace a bent or missing metal bracket that secures the trackpad cable connector to the logic board compatible with the 2016 to 2020 model 13 inch MacBook Pro Retina Tou...
MacBook Pro 13" Retina (2018-2020) USB-C Cable Bracket
Replace a bent or missing bracket that secures the USB-C cable to the logic board in a 2018 to 2020 model 13" MacBook Pro with Retina Display.
MacBook Pro 13" (A2251, 2020) Upper Case Assembly
Replace an upper case, keyboard, and battery compatible with a 2020 model A2251 MacBook Pro 13 inch laptop with four Thunderbolt Ports.
MacBook Pro 13" (A2251, 2020) Lower Case
Replace a lower case compatible with a 2020 model A2251 MacBook Pro 13 inch laptop with four Thunderbolt Ports.
MacBook Pro 13" (A2251, 2020) 2.0 GHz Logic Board with Paired Touch ID Sensor
Replace a damaged or malfunctioning 2.0 GHz Core i5 Motherboard. The Touch ID sensor is paired to the logic board and is included.
Geräteinformation
Released in 2020, this 13" Macbook Pro features Quad-core Intel Core i5 or i7 processors. Model A2251.
The most common repairs with the 13" 2020 model MacBook Pro 13" with Four Thunderbolt Ports laptops are replacing a dead battery or a damaged display assembly.
The battery is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2019 repair guides for step-by-step instructions on how to make the fix.
