Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Battery
  • MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Battery / Fix Kit
  • MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Battery / New / Part Only
139,99 $
139,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
This MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) replacement battery fix kit includes all the parts, tools, and adhesive you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 4090 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Battery adhesive is preinstalled to improve the quality of your repair.
Battery degradation is an inevitable part of your MacBook Pro's lifespan, extend it with this new replacement battery compatible with MacBook Pro 13" Retina (Touch Bar, Late 2016-2017). Factory-installed MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Die Einheit enthält
Die Einheit enthält
  • New Replacement Battery compatible with a late 2016 or mid 2017 model MacBook Pro 13" Retina with Touch Bar
  • Installation Adhesive
Kit Inhalt
Kit Inhalt
Kompatibilität
Kompatibilität
  • MacBook Pro 13" Touch Bar A1706 Late 2016 to Mid 2017
Eigenschaften
Eigenschaften
Model #:
A1819
Watt Hours:
49.2 Wh
Voltage:
11.41 V
Milliamp Hours:
4310 mAh
Manufacturer:
Aftermarket
Kompatibilität
MacBook Pro 13" Touch Bar 2017
A1706 (EMC 3163) 3.1 GHz
A1706 (EMC 3163) 3.3 GHz
A1706 (EMC 3163) 3.5 GHz
MacBook Pro 13" Touch Bar 2016
A1706 (EMC 3071) 2.9 GHz
A1706 (EMC 3071) 3.1 GHz
A1706 (EMC 3071) 3.3 GHz
Kundenbewertungen
