MacBook Pro 15" Unibody Hard Drives SATA
Grab a toolkit for your MacBook Pro 15" Unibody model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Wähle dein MacBook Pro 15" Unibody Modell:
Ersatzteile für MacBook Pro 15" Unibody:
MacBook and MacBook Pro Unibody Plastic Feet
Replace the black plastic feet on the lower case of your Unibody MacBook or MacBook Pro.
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery
Replacement battery, compatible with all Early 2011, Late 2011, and Mid 2012 15" Unibody MacBook Pros.
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
Macbook Pro Unibody Lower Case Screw Set
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pr...
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
MacBook Pro 15" Unibody (Mid 2009-Mid 2010) Replacement Battery
Replace the battery for the Mid 2009/Mid 2010 MacBook Pro 15"
PC3L-12800 8 GB RAM Chip
RAM / 8 GB / PC3L-12800 / Low Profile / 204 pin, 1600 MHz
PC3-8500 4 GB RAM Chip
Replace or upgrade the RAM in your desktop, laptop, or game console for faster performance. Low Profile / 204 pin / 1066 MHz
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector.
Geräteinformation
In October of 2008 Apple released the MacBook Pro 15" Unibody with an aluminum case drilled from a single aluminum brick. With the exception of the 2.53 GHz Mid 2009 model, all 15" Unibody models feature 2 graphics cards, one for power saving casual use and one for graphics-intensive processing.
The most common repairs with the MacBook Pro 15" Unibody models are replacing a dead battery, upgrading the hard drive, or upgrading the RAM. Choose a model for more specific information.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody MacBook Pro 15" Unibody Repair for step-by-step instructions on how to make the fix.
