Repariere deine Sachen
Recht auf Reparatur
Store
MacBook Pro 15" (Model A1150) Left Fan
  • MacBook Pro 15" (Model A1150) Left Fan
29,99 $
29,99 $
Artikelbeschreibung
Beschreibung
Beschreibung
An aging left fan may become noisy and inefficient or simply fail and stop spinning, leaving your MacBook Pro 15" (Model A1150) to overheat and eventually damaging your processors. Replace a defective fan to fix overheating problems or to keep your laptop running quietly.
Kompatibilität
Kompatibilität
  • MacBook Pro 15" A1150
Eigenschaften
Eigenschaften
Part #:
922-7193
Kompatibilität
MacBook Pro 15" Core Duo Model A1150
A1150 (EMC 2101) 1.83 GHz
A1150 (EMC 2101) 2 GHz
A1150 (EMC 2101) 2.16 GHz
Reparatur-Geschichten
Nutzeravatar
Mein Problem
The left fan started making noise constantly.
Meine Reparatur
The repair went pretty smoothly. One of the metal tabs on the case broke off so that case screw couldn't go back in and another case screw just wouldn't go back without stripping. Also, took several tries to get the top back on the case. The tabs just . . .
Nutzeravatar
Mein Problem
The computer was overheating and began making a noise.
Meine Reparatur
The repair went excellently. To be honest this wasn't the first time I had had to perform surgery on this Macbook. A few years ago I had replaced the hard drive so I was already familiar with disassembling the computer and had the correct tools.
Mein Rat
T . . .
Nutzeravatar
Mein Problem
The fan died.
Meine Reparatur
Excellent! The photo tutorial walked me thru the process and I had no issues.
Mein Rat
Keep doing what you're doing, I'll be back when I have to make my next repair.
Nutzeravatar
Mein Problem
the fan began to make so much noise, i installed the software smcfan to saw whats was going on and i realized the left fan was dead 0 rpm
Meine Reparatur
perfect, i printed the guide and step by step i changed the fan, so easy
Mein Rat
Only be carefull by pulling the plugs, better use the Spudger if you can.
When remove the . . .
Nutzeravatar
Mein Problem
The fan in my Macbook pro was creating a lot of noise. I needed to replace it.
Meine Reparatur
It went well. It was a little scary but I was successful.
Mein Rat
Step 12 of the instructions was not as specific as I would have liked. I ultimately figured out how to do it but I was worried that I might be causing harm to my sys . . .
Nutzeravatar
Mein Problem
I replace my optical drive with a SSD.
Meine Reparatur
The installation was easy, no problem.
But when I install the OS on the SSD and boot from it, I can no longer enter sleep mode. I've tried to google the problem but have found nothing about that kind of behaviour. Anyone got a suggestion?
Mein Rat
Nope, installation was . . .
Nutzeravatar
Mein Problem
A customer left a Macbook Pro with a faulty left fan. I went to ifixit.com for ordering not for being the cheapest on the market but for ideological reasons. Help the ones helping me!
Meine Reparatur
Did work great then checking the super guide at ifixit.com
Mein Rat
Take it easy with Apple brand parts.
Nutzeravatar
Mein Problem
My right fan was dead, never showed as running when I checked istat pro. Led to my mac running hotter than it should. Figured I would replace both since I already had to open it for the one.
Meine Reparatur
The only complaint was UPS delivered my fans a day late when I paid for next day air. The only difficult part . . .
Nutzeravatar
Mein Problem
My old fellow (A MBP 2006) started to be noisy. The left fan was making a sound like a blender at top speed.
Meine Reparatur
The guide was incredibly helpful, the problems start when I tried to open the upper case, I broke some parts of it (Where you put the screws). Then I realized that some tapes where put on pla . . .
Nutzeravatar
Mein Problem
Damaged and noisy fan.
Meine Reparatur
It took about 45 minutes. The guide was very helpful. It was kind of hard taking the keyboard on and off, but I am pretty dumb when it comes to computers. I damaged a piece putting the keyboard back on, but it doesn't affect the performance of my computer. After replacing the f . . .
Mehr anzeigen
