MacBook Pro 15" (Model A1150) Right Fan
  • MacBook Pro 15" (Model A1150) Right Fan
29,99 $
29,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
Schau dich im Store um
Artikelbeschreibung
Beschreibung
Beschreibung
Make sure you have identified your MacBook Pro correctly. You can use our Identify Your Mac.
If your screen is facing you, this is the fan on the right side of the machine. Includes fan and surrounding metal bracket.
Worse than spending a weekend with a Swedish supermodel, living with an inanimate object hotter than yourself often results in feelings of inadequacy, depression, and unbridled ice cream infatuations. Best your 15" MacBook Pro's hotness and avoid the empty calories by replacing its worn-out right fan today.
Kompatibilität
Reparatur-Geschichten
Nutzeravatar
crystalballbates's Story Photo #189368
Mein Problem
Downloaded smcFanControl, and discovered why it was running hot. It always ran hot, figured early Dual Core Intel model was "hot" literally as well as figurally. But with smcFanControl I could see right fan was dead. Confirmed when removed right fan resisted spinning.
Meine Reparatur
Great. First got baggie for eve . . .
Nutzeravatar
Mein Problem
The fan was making noise and getting worse.
Meine Reparatur
The repair went flawlessly. Twenty minutes. In and out. Problem solved. iFixit's repair guides are great!
Mein Rat
Make sure all the screws are out before you start trying to pry the top off.
Nutzeravatar
Mein Problem
Old Macbook Pro had a noisy (think garbage disposal) right side fan.
Meine Reparatur
Easy.
Mein Rat
$50 fan (eek) beats a new laptop.
Nutzeravatar
Mein Problem
My right fan was dead, never showed as running when I checked istat pro. Led to my mac running hotter than it should. Figured I would replace both since I already had to open it for the one.
Meine Reparatur
The only complaint was UPS delivered my fans a day late when I paid for next day air. The only difficult part . . .
Nutzeravatar
Mein Problem
Right fan was not running and that was putting more burden on the left fan and some processes caused the machine to get too hot.
Meine Reparatur
This was my second experience opening the MBP so I knew my way to the inside. I replaced both fans and the left fan is harder to replace than the right because there are so . . .
Nutzeravatar
Mein Problem
fans broken
Meine Reparatur
Good
Mein Rat
Yes!
Nutzeravatar
Mein Problem
The old fans stopped working
Meine Reparatur
It went flawlessly. The instructions were easy to follow.
Mein Rat
Just make sure you follow the instructions and if you take any tape off, remember to put it back.
Nutzeravatar
Mein Problem
Well. As like everyone, once you hear a noise, you start to get frustrated. The Noise goes off and comes back on, and keeps bothering you. So next step, is either break your computer, or take it to someone to repair it. and let them charge you a fortune to fix a little problem. which maybe you can f . . .
Nutzeravatar
Mein Problem
My aging mac book pro began making loud fan noise whenever I watch Hi-def videos on youtube ( or on any other flash based video sites ). The fan noise got so loud, that I almost thought it was about to explode.
Meine Reparatur
The repair guide from iFixIt was clear and easy to follow. I was able to disassemble my . . .
Nutzeravatar
Mein Problem
Noisy fan on 15" MBP 1,1 -- Apple would not touch it because it is 'too old'. Baloney! iFixit to the rescue! All went very well -- new fan is quiet!
(Had already replaced other fan -- I do lots of video compression, and this thing gets HOT!)
Meine Reparatur
Very well. Had to improvise with some electrical tap . . .
Mehr anzeigen
