Mac MacBook Pro MacBook Pro 16" Case Components
Store
Grab a toolkit for your MacBook Pro 16" model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Du kennst dein Modell nicht? Mac identifizieren
Wähle dein MacBook Pro 16" Modell:
MacBook Pro 16" (2019) Upper Case Assembly / A-Stock / Dark Gray
Replace an upper case, keyboard, and battery compatible with the 2019 model A2141 MacBook Pro 16 inch laptop.
299,99 $
MacBook Pro 16" (2019) Heat Sink Brackets
Replace the metal spring brackets that press the heat sink against the CPU.
19,99 $
MacBook Pro 16" (2019) Lower Case / New / Silver
Replace a scratched or dented lower case compatible with a 2019 model 16" MacBook Pro.
99,99 $
MacBook Pro 16" (2019) Touch Bar Cable Brackets
Replace a bent or missing bracket securing the touch bar cable connector 2019 model 16" MacBook Pro laptop.
19,99 $
MacBook Pro 16" (2019) Touch ID Sensor Cable Bracket
Replace a bent or missing bracket securing the touch ID sensor cable connector in a 2019 model 16" MacBook Pro laptop.
19,99 $
MacBook Pro 16" (2019) USB-C Cable Brackets
Replace a bent or missing bracket securing a USB-C cable connector to the logic board in a 2019 model 16" MacBook Pro laptop.
19,99 $
MacBook Pro 16" (2019) Display Cable Brackets
Replace a bent or missing bracket securing the display cable to the logic board and case in a 2019 model 16" MacBook Pro laptop.
19,99 $
MacBook Pro 16" (2019) Headphone Jack Cable Bracket
Replace a bent or missing bracket securing the headphone jack cable to the logic board in a 2019 model 16" MacBook Pro laptop.
19,99 $
MacBook Pro 16" (2019) Trackpad Cable Bracket
Replace a bent or missing bracket securing the trackpad cable to the logic board in a 2019 model 16" MacBook Pro laptop.
19,99 $
MacBook Pro 16" (2019) Display Hinge Covers
Replace a damaged or missing plastic cover for the display hinges in a 2019 model 16" MacBook Pro laptop.
24,99 $
Angezeigte Artikel 1 - 10 von 10
Geräteinformation
Catering to the working professional, the MacBook Pro is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
Please select your version above for parts and support!
