Repariere deine Sachen
Recht auf Reparatur
Store
Parts Mac MacBook Pro Optical Drives
Store
Grab a toolkit for your MacBook Pro model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Du kennst dein Modell nicht? Mac identifizieren
Unibody Laptop Dual Drive
Increase the storage space in your laptop by replacing the optical drive with a second hard drive or SSD.
Von 24,99 $
SATA Optical Drive USB Cable
Connect an optical drive to your computer via USB with this part.
19,99 $
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) 8x SATA SuperDrive (Used)
Replace a broken or damaged SuperDrive for your Mid 2009 to Mid 2012 MacBook Pro 15" Unibody with this part. This part includes the metal mounting bracket but does not in...
49,99 $
MacBook Pro 13" Unibody 8x SATA SuperDrive (Used)
Replace a malfunctioning optical drive compatible in your 13" Unibody MacBook Pro. Model #UJ8A8, UJ898A, UJ868A. Part #661-5165, 661-5502, 661-5865.
29,99 $
Unibody (Post-Early 2009) 8x SATA SuperDrive / Used
Replace a broken or damaged SuperDrive for your Post-Early 2009 MacBook Unibody with this part. This part does not include the metal mounting bracket and orange ribbon ca...
44,99 $
MacBook Pro 13" Unibody (Early 2011-Mid 2012) SATA SuperDrive Cable
This cable connects the SuperDrive to the logic board.
19,99 $
Unibody 8x SATA SuperDrive (Pre-Mid 2009) / Used
Replace a malfunctioning or noisy optical drive.
49,99 $
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) SATA SuperDrive Cable
Replace a damaged or missing cable connecting the SuperDrive to the logic board.
Von 19,99 $
MacBook Pro 17" Unibody (Early-Mid 2009) Used 8x SATA SuperDrive
DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 10x CD-RW write
39,99 $
MacBook Pro 13" Unibody (A1278 Mid 2009-Mid 2010) SATA SuperDrive Cable
25,99 $
Angezeigte Artikel 1 - 10 von 12
Geräteinformation
Catering to the working professional, the MacBook Pro is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
We sell dozens of MacBook Pro upgrades and repair parts. It's easy, fast, and safe to max out your machine! Two RAM slots allow for an easy memory boost. Need more storage? Drop in a larger-capacity 500 GB 7200 RPM 9.5mm SATA hard drive for some much-needed space as well as speed. An 85-watt MagSafe adapter will keep your machine juiced through even the most power demanding processes.
Select your version above for parts and assistance!
