Halberd Spudger
  • Halberd Spudger
  • Halberd Spudger
  • Halberd Spudger
  • Halberd Spudger
  • 360°
360
Halberd Spudger
2,99 $
2,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Artikelbeschreibung
Beschreibung
Beschreibung
Hook and Slice Your Way to Repair Victory
  • An excellent compliment to our Standard Spudger
  • Specifically shaped for electronics repair, this spudger features a hook for scooping, scraping, pulling, and guiding.
  • Measuring in at only 0.6 mm thick, the razor-thin blade features a handy depth guide, allowing for precise depth control.
  • Made of the same ESD-safe fiber-reinforced nylon as the regular spudger.
  • Loosen adhesive, flip up connectors, pull cables, clean out grooves. This spudger allows for a variety of tasks unachievable with the standard spudger.
Reparatur-Geschichten
Brian Morton's Story Photo #1318477
Brian Morton's Story Photo #1318480
Brian Morton's Story Photo #1318479
Mein Problem
I had an old 2007 15" MacBook Pro that I quit using after I spilled wine in they keyboard for the second time (I upgraded to a 13" MacBook Air), and so it was sitting around gathering dust when a friend mentioned iFixit. After poking around through the site, I realized I could turn the old 15" into . . .
Mein Problem
the battery was dying within a few hours.
Meine Reparatur
smoothly.
Mein Rat
i bought the tape kit from ifixit. its good for 2 corners, so i added a little bit more 2 sided tape. its not as good quality, but it should be better then nothng.
you will also want a microfiber and alcohol so you can clean the back panel off since . . .
Mein Problem
The SuperDrive on the MBP was just spitting out cd's and DVD's left and right. It was not good and the customer was frustrated and upset. I was able to get a used certified part and fix it with ease, which made my client happy.
They had it that same afternoon.
Meine Reparatur
Repair was easier than I expected.
Mein Rat
"Take . . .
