P2 Pentalobe Screwdriver iPhone
The nicest iPhone driver available anywhere. Made in the USA with a lifetime warranty.
ESD handle with swivel top.
$11.95
$11.95
Wir senden dir eine E-Mail, sobald das Produkt wieder verfügbar ist.
Produktdetails
Funktionen
Funktionen
The essential tool for the iPhone hardware hacker.
  • Fits the tiny 5-point pentalobe screws found on the bottom of the iPhone 4, 4S, 5, 5s, 5c, 6, and 6 Plus.
  • Sturdy precision driver with a solid metal shaft, rubberized plastic handle, and spinning top.
  • Fixed driver makes a great complement to a 54 Bit Driver Kit to speed up your more frequent repairs.
  • Upgrade to pro for an ESD safe professional-grade driver.
Also available as part of the Pro Tech Screwdriver Set
Reparatur-Geschichten
Nutzeravatar
Mein Problem
My wife dropped her iPhone 6 and it popped the screen out and dented the corner. I used the Pentalobe #2 bit to remove bottom of the screen so I could place it back in properly.
Meine Reparatur
Very well.
Mein Rat
NA
Nutzeravatar
Mein Problem
The screen start flashing when turn the phone on. Save money buying the tools and fixing it myself, plus the experience
Meine Reparatur
Perfectly
Mein Rat
Saw a video on you tube
Nutzeravatar
Mein Problem
My iPhone 5s could not go 12 hours without needing to be charged. And this was with very minor use.
Meine Reparatur
The repair is a little tedious, but with patience and care, it can be done without hurting the phone.
Mein Rat
The pulling part, when you pull the old battery adhesive strip off, be very slow and gentle, specia . . .
Nutzeravatar
Mein Problem
A friend took his iPhone 6Plus scuba diving with a not so waterproof case.
Meine Reparatur
Was able to get the battery out and replace it...sadly it did not charge. The tool kit is amazing...every tool you need to make it go smoothly. I had watched a video with a 10 year old showing me how to open the case with an 1 . . .
Nutzeravatar
Mein Problem
I water damaged my 6s.
Meine Reparatur
It went great!
Mein Rat
Getting the front sensors, camera, and earpiece is definitely hard, but not too hard. Watch out for that.
Nutzeravatar
Mein Problem
Back panel of iPhone was scratched, including across the area over the camera lens, making photo quality terrible
Meine Reparatur
Took less than a minute, super super easy
Mein Rat
Note that the back panel on the iPhone 4 slides up a little to unlatch, you don't pry it off, you slide it a little. Reverse the motion to put the . . .
Nutzeravatar
Mein Problem
screen cracked
Meine Reparatur
The repair was fairly easy- you do need a micro screwdriver (smaller than the smallest you can get at Lowes or HD- so, if you don't already have one, get one from ifixit, along with the P2 pentalobe driver. The screws are so tiny that I can't pick them up with my fingers. Must use tw . . .
Nutzeravatar
Mein Problem
Cracked display
Meine Reparatur
Instructions were clear and accurate! Finished in 15 minutes. Delivery came in 2 days after my order...3 days earlier than expected!
Mein Rat
I can see how reinstalling the display may put undue pressure on the tiny piece of glass under the home button. Be careful when snapping the assembly in . . .
Nutzeravatar
Mein Problem
I have a FIIO X5s High Def music player and the back had been pulled open by the magnetic stand that I was using to hold it to my cars dash. It has 2 small screws that hold the back plate in place. The screw drive that I received wass perfect for the job. I was able to replace the back plate and sec . . .
Nutzeravatar
Mein Problem
Iphone drained battery had to repair, but didnt have tools... Lost em
Meine Reparatur
Easy fix just waited for shipping
Mein Rat
Beready for a long but worthwhile wait for shipping, mine didnt have tracking but was told earlier on that if have to wait 2-7 weeks for it to come
Mehr anzeigen
