P2 Pentalobe Screwdriver iPhone
  • P2 Pentalobe Screwdriver iPhone
  • P2 Pentalobe Screwdriver iPhone / iFixit - Made in Germany / New
  • P2 Pentalobe Screwdriver iPhone / Moody - Made in USA / New
8,99 $
8,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Artikelbeschreibung
Beschreibung
Beschreibung
Use this precision P2 pentalobe screwdriver to open iPhone and Apple devices. The P2 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of iPhones. The driver is compatible with the security screws on the bottom of all models of iPhone since the iPhone 4: iPhone 4/4S, iPhone 5/5s/5c, iPhone 6/6 Plus/6s/6s Plus, iPhone SE, iPhone 7/7 Plus, and iPhone 8/8 Plus.
The iFixit P2 pentalobe screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision P2 pentalobe screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Reparatur-Geschichten
Mein Problem
Input via digitizer became intermittently erratic. I could scroll screen with finger above screen not touching. Pressing one area made phone act like I had pressed a different area. There was a light streak down screen. This problem was intermittent and would come and go while phone was just sit . . .
Mein Problem
Battery was draining within 2 hours and % remaining was never accurate (at 100%) and then would die.
Meine Reparatur
Super simple! Make sure that you have that pentalobe (?) screw driver.
Mein Rat
My battery was taped in with double sided tape. And was very difficult to remove until I heated up the tape. I heated up a hot/ . . .
Mein Problem
My wife dropped her iPhone 6 and it popped the screen out and dented the corner. I used the Pentalobe #2 bit to remove bottom of the screen so I could place it back in properly.
Meine Reparatur
Very well.
Mein Rat
NA
Mein Problem
The screen start flashing when turn the phone on. Save money buying the tools and fixing it myself, plus the experience
Meine Reparatur
Perfectly
Mein Rat
Saw a video on you tube
Mein Problem
My iPhone 5s could not go 12 hours without needing to be charged. And this was with very minor use.
Meine Reparatur
The repair is a little tedious, but with patience and care, it can be done without hurting the phone.
Mein Rat
The pulling part, when you pull the old battery adhesive strip off, be very slow and gentle, specia . . .
Mein Problem
A friend took his iPhone 6Plus scuba diving with a not so waterproof case.
Meine Reparatur
Was able to get the battery out and replace it...sadly it did not charge. The tool kit is amazing...every tool you need to make it go smoothly. I had watched a video with a 10 year old showing me how to open the case with an 1 . . .
Mein Problem
I water damaged my 6s.
Meine Reparatur
It went great!
Mein Rat
Getting the front sensors, camera, and earpiece is definitely hard, but not too hard. Watch out for that.
Mein Problem
Back panel of iPhone was scratched, including across the area over the camera lens, making photo quality terrible
Meine Reparatur
Took less than a minute, super super easy
Mein Rat
Note that the back panel on the iPhone 4 slides up a little to unlatch, you don't pry it off, you slide it a little. Reverse the motion to put the . . .
Mein Problem
screen cracked
Meine Reparatur
The repair was fairly easy- you do need a micro screwdriver (smaller than the smallest you can get at Lowes or HD- so, if you don't already have one, get one from ifixit, along with the P2 pentalobe driver. The screws are so tiny that I can't pick them up with my fingers. Must use tw . . .
Mein Problem
Cracked display
Meine Reparatur
Instructions were clear and accurate! Finished in 15 minutes. Delivery came in 2 days after my order...3 days earlier than expected!
Mein Rat
I can see how reinstalling the display may put undue pressure on the tiny piece of glass under the home button. Be careful when snapping the assembly in . . .
Mehr anzeigen
