Tri-point Y0 Screwdriver
  • Tri-point Y0 Screwdriver / iFixit - Made in Germany / Fixed Blade
  • Tri-point Y0 Screwdriver / Moody - Made in USA / Fixed Blade
8,99 $
8,99 $
Wir senden dir eine E-Mail, sobald der Artikel wieder verfügbar ist.
Artikelbeschreibung
Beschreibung
Beschreibung
Use this precision Tri-point Y0 DIY or professional electronics repair. Slightly different from a "tri-wing", this driver fits some of the smaller "tri" screws found on Apple track pads and other products.
The iFixit Tri-point Y0 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Tri-point Y0 screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Reparatur-Geschichten
Mein Problem
The battery was almost 9 years old and only had 57% charge capacity left.
Meine Reparatur
The repair was very simple. I believe it took longer to restart the laptop then to do the replacement.
Mein Rat
Make sure to read, understand and follow the directions in the guide.
Mein Problem
2 problems: First, battery losing life, then computer could not communicate with hard drive.
Meine Reparatur
Went well. The drive cable was a bit of a challenge because of the need to bend it at sharp right angles to fit stair-step in upper case where it gets fastened with screws, but after several tries, got it to . . .
Mein Problem
Battery was completely dead
Meine Reparatur
Super easy and very helpful guide to understand and follow
Mein Rat
You guys do great work thanks!
Mein Problem
Original battery was swollen
Meine Reparatur
Nice and simple
Mein Rat
Be sure to read the guide. There was one connector I originally overlooked that the guide pointed out.
Have the right tools. The screws that hold the battery in place would be badly damaged and likely the screwdriver I used would be too.
Mein Problem
Electrical part which had a relative simple problem to fix.
Meine Reparatur
Very well - as expected.
Mein Rat
When unsuccessful finding the appropriate tool at the local hardware store, go to the internet - especially the iFixit website.
Mein Problem
No problem, only self install 0,35$/GB common ssd Instead of 3 times the price of Apple's ssd...
Meine Reparatur
Good. ifixit video tutorial + adhesive parts make it easy
Mein Rat
Carefully remove the bottom Edge adhesive. Don't use a cutter to cut it , Risk of scratching the back of the bottom glass panel edge , (visible on . . .
Mein Problem
Only my grandson knows
Meine Reparatur
Hasn't started yet-- gets parts Dec. 25
Mein Rat
Ask for recipients email
Mein Problem
Screen was broken and I decided to fix it instead of replacing the whole unit.
Meine Reparatur
We followed the instructions step by step and it went very well. The phillips screwdriver ended up not really working on the first set of screws but i had another that was better but other than that everything went really . . .
Mein Problem
have used ifixit site before and was very pleased with outcome
Meine Reparatur
the repair went smoothly; my trackpad repair came without the cable so i needed to swap that over so there should be a couple of pics on how to do that
Mein Rat
don't be afraid to tackle such a project; plenty of guides and tools available to do th . . .
Mein Problem
My trackpad had become extremely hard to click and took a lot of force to do any clicking. So, I decided to replace the pad and upgrade the RAM while I was inside the computer.
Meine Reparatur
The repair was simple and easy and took about 25 minutes to complete. I even did a lot of cleaning inside the computer while . . .
Mehr anzeigen
