Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein PlayStation zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. (TC) PlayStation Teardown, (TC) PlayStation Teardown: Schritt 1, Bild 1 von 1
    • Flip the unit upside down to access the six screws on the bottom.
    • Remove the six screws indicated with a Phillips-head screwdriver. All the screws are of the same length.
  2. (TC) PlayStation Teardown: Schritt 2, Bild 1 von 1
    • Turn the unit back over, and pull the top half up and away from the device.
  3. (TC) PlayStation Teardown: Schritt 3, Bild 1 von 1
    • Unplug the laser assembly's power cable and ribbon cable from the main board.
    • Remove the two screws on the memory card/controller port, disconnect the ribbon cable, and lift it out of the case.
  4. (TC) PlayStation Teardown: Schritt 4, Bild 1 von 2 (TC) PlayStation Teardown: Schritt 4, Bild 2 von 2
    • To remove the power supply, disconnect the cable and remove the two screws, then lift it out of the case.
  5. (TC) PlayStation Teardown: Schritt 5, Bild 1 von 2 (TC) PlayStation Teardown: Schritt 5, Bild 2 von 2
    • Remove the 3 screws from the shield.
  6. (TC) PlayStation Teardown: Schritt 6, Bild 1 von 2 (TC) PlayStation Teardown: Schritt 6, Bild 2 von 2
    • Remove the 5 Phillips screws.
    • You can now lift the main board out of the case.
  7. (TC) PlayStation Teardown: Schritt 7, Bild 1 von 2 (TC) PlayStation Teardown: Schritt 7, Bild 2 von 2
    • Lift the RF shield out of the case.
  8. (TC) PlayStation Teardown: Schritt 8, Bild 1 von 2 (TC) PlayStation Teardown: Schritt 8, Bild 2 von 2
    • Reinstall the RF shield by dropping it in and lining up the slots and tabs.
  9. (TC) PlayStation Teardown: Schritt 9, Bild 1 von 2 (TC) PlayStation Teardown: Schritt 9, Bild 2 von 2
    • Replace the main board. Only install the screws indicated in red.
  10. (TC) PlayStation Teardown: Schritt 10, Bild 1 von 1
    • Replace the top shield, and secure with the 3 screws indicated.
    • Reinstall the memory card / controller module. Connect the ribbon cable and replace the 2 screws.
  11. (TC) PlayStation Teardown: Schritt 11, Bild 1 von 1
    • Align the optical drive assembly with the three pegs.
    • Reconnect the power and data cables for the optical drive.
  12. (TC) PlayStation Teardown: Schritt 12, Bild 1 von 1
    • Slide the cover on the system in the same way you took it off and replace the black screws indicated.
  13. (TC) PlayStation Teardown: Schritt 13, Bild 1 von 1
    • Plug in the console and turn it on.
    • Thanks for looking at my teardown!
Nick
95.146 Reputation
60 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 22
Letzte 30 Tage: 105
Insgesamt: 44,540
