Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein American Era Electric Rice Cooker zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. American Era Electric Rice Cooker Teardown, Rice Cooker Teardown: Schritt 1, Bild 1 von 1
    • Start with the rice cooker unplugged, on a flat surface.
  2. American Era Electric Rice Cooker Teardown, Remove Pot and Lid: Schritt 2, Bild 1 von 3 American Era Electric Rice Cooker Teardown, Remove Pot and Lid: Schritt 2, Bild 2 von 3 American Era Electric Rice Cooker Teardown, Remove Pot and Lid: Schritt 2, Bild 3 von 3
    • Remove the lit and pot and turn upside down.
  3. American Era Electric Rice Cooker Teardown, Remove Bottom Plate: Schritt 3, Bild 1 von 3 American Era Electric Rice Cooker Teardown, Remove Bottom Plate: Schritt 3, Bild 2 von 3 American Era Electric Rice Cooker Teardown, Remove Bottom Plate: Schritt 3, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the two screws.
    • Remove the bottom plate by lifting one of the rubber feet.
  4. American Era Electric Rice Cooker Teardown, Remove Internal Screws: Schritt 4, Bild 1 von 2 American Era Electric Rice Cooker Teardown, Remove Internal Screws: Schritt 4, Bild 2 von 2
    • We're inside! Here's our first look at the circuitry. Let's take it apart.
    • Use a 3/8" or 8 mm flathead screwdriver to remove these six screws.
  5. American Era Electric Rice Cooker Teardown, Bend Tab: Schritt 5, Bild 1 von 2 American Era Electric Rice Cooker Teardown, Bend Tab: Schritt 5, Bild 2 von 2
    • Find the metal tab that connects the center button to the switch lever.
    • Use pliers to bend the metal tab into a U shape.
    • Align the tab with the slot so that it falls through.
  6. American Era Electric Rice Cooker Teardown, Remove Heating Element: Schritt 6, Bild 1 von 2 American Era Electric Rice Cooker Teardown, Remove Heating Element: Schritt 6, Bild 2 von 2
    • Turn the rice cooker right-side up.
    • Grab the center button and pull the heating plate upward. The gray metal ring should come out with it.
  7. American Era Electric Rice Cooker Teardown, Remove Temp. Sensor: Schritt 7, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the screw connecting the temperature sensor to the heating element.
    • Remove the temperature sensor.
  8. American Era Electric Rice Cooker Teardown, Remove Center Button: Schritt 8, Bild 1 von 3 American Era Electric Rice Cooker Teardown, Remove Center Button: Schritt 8, Bild 2 von 3 American Era Electric Rice Cooker Teardown, Remove Center Button: Schritt 8, Bild 3 von 3
    • Three bent metal tabs connect the center button to the heating element. Use pliers to flatten these three tabs.
    • Remove the center button from the heating element.
  9. American Era Electric Rice Cooker Teardown, Remove Control Panel: Schritt 9, Bild 1 von 2 American Era Electric Rice Cooker Teardown, Remove Control Panel: Schritt 9, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the screw that secures the control panel.
    • Remove the control panel from the outside of the rice cooker.
  10. American Era Electric Rice Cooker Teardown, Disassemble Control Panel: Schritt 10, Bild 1 von 3 American Era Electric Rice Cooker Teardown, Disassemble Control Panel: Schritt 10, Bild 2 von 3 American Era Electric Rice Cooker Teardown, Disassemble Control Panel: Schritt 10, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the screw securing the rectangular fiberglass plate. This should free the two light bulbs.
    • Use a Phillips #1 screwdriver to remove two screws securing the switch lever to the control panel plate. Remove the switch lever.
  11. American Era Electric Rice Cooker Teardown, Disassemble Switch: Schritt 11, Bild 1 von 2 American Era Electric Rice Cooker Teardown, Disassemble Switch: Schritt 11, Bild 2 von 2
    • Use pliers or hex wrench to hold the nut while using a Phillips #1 screwdriver to remove the screw holding the switch assembly together.
    • Pull the switch assembly apart into its parts. Careful not to lose any of these small parts!
  12. American Era Electric Rice Cooker Teardown, All Done!: Schritt 12, Bild 1 von 1
    • And here we have it: a fully disassembled rice cooker.
Travis Taylor
464 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 10-40, Amido Spring 2013 Mitglied von Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Mitglieder
37 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 42
Insgesamt: 3,958
