Zum Hauptinhalt wechseln
Fujifilm X30 EVF Replacement/Teardown
Was du brauchst
  1. Fujifilm X30  EVF Replacement/Teardown, Remove EVF: Schritt 1, Bild 1 von 3 Fujifilm X30  EVF Replacement/Teardown, Remove EVF: Schritt 1, Bild 2 von 3 Fujifilm X30  EVF Replacement/Teardown, Remove EVF: Schritt 1, Bild 3 von 3
    • Follow disassembly instructions from disassembly guide through step 17
    • unscrew 2 philips screws.
    • Slide the EVF to remove it. Becareful "play" button will come out too.
    Frag FixBot
    Kommentar hinzufügen
  2. Fujifilm X30  EVF Replacement/Teardown, Separate lens block and LCD: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Adhesive sealing tape can be just worked out with tweezers to unstick it without removing it.
    Frag FixBot
  3. Fujifilm X30  EVF Replacement/Teardown, EVF lens block disassembly: Schritt 3, Bild 1 von 3 Fujifilm X30  EVF Replacement/Teardown, EVF lens block disassembly: Schritt 3, Bild 2 von 3 Fujifilm X30  EVF Replacement/Teardown, EVF lens block disassembly: Schritt 3, Bild 3 von 3
    Magnetic Project Mat
    $19.95
    • disassembly plastic cover
    • unscrew plastic wheel.
    • Becareful not to loose the little metal ball
    • Working on a magnetic mat can be handful
    • when re-assembling:
    • put the first plastic wheel on place
    • Drop the ball in the hole, and put the spring over it
    • Then screw the second plastic wheel over it
    Frag FixBot
  4. Fujifilm X30  EVF Replacement/Teardown, EVF lens teardown: Schritt 4, Bild 1 von 3 Fujifilm X30  EVF Replacement/Teardown, EVF lens teardown: Schritt 4, Bild 2 von 3 Fujifilm X30  EVF Replacement/Teardown, EVF lens teardown: Schritt 4, Bild 3 von 3
    • To remove lens block, you have to push the 2 metal rods from one side to the other. The rods have one end thinner than the other
    • Now you can remove every lens in order to clean them from dust or humidity
    • When re-assembling, there's only one way to get them back in, so keep track of lenses order and direction when removing each one of them. Or wou'll have to try many times to comlete the puzzle.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 11
Letzte 30 Tage: 66
Insgesamt: 2,955
