Zum Hauptinhalt wechseln
Disassembling Fujifilm X30 Camera
Was du brauchst
    1. Disassembling Fujifilm X30 Camera, Battery: Schritt 1, Bild 1 von 2 Disassembling Fujifilm X30 Camera, Battery: Schritt 1, Bild 2 von 2
      • Turn the camera upside down.
      • Place your thumb on the switch, and slide it towards the center of the camera.
      • The compartment will pop open.
      Frag FixBot
      Kommentar hinzufügen
    2. Disassembling Fujifilm X30 Camera: Schritt 2, Bild 1 von 1
      • Once you have the battery compartment open, slide the orange tab away from the battery until it ejects.
      Frag FixBot
    3. Disassembling Fujifilm X30 Camera: Schritt 3, Bild 1 von 1
      • Pull the battery out.
      Frag FixBot
    1. Disassembling Fujifilm X30 Camera, Motherboard: Schritt 4, Bild 1 von 3 Disassembling Fujifilm X30 Camera, Motherboard: Schritt 4, Bild 2 von 3 Disassembling Fujifilm X30 Camera, Motherboard: Schritt 4, Bild 3 von 3
      • Begin by removing the outside screws using a Phillips #000 Screwdriver:
      • Remove the three 3.6 mm silver screws located on the bottom of the camera.
      • Remove all four of the 4.7 mm screws from the sides of the camera.
      Frag FixBot
    2. Disassembling Fujifilm X30 Camera: Schritt 5, Bild 1 von 2 Disassembling Fujifilm X30 Camera: Schritt 5, Bild 2 von 2
      • Remove all screws below using a Phillips #000 Screwdriver:
      • Lift up the screen and remove the two 4.5 mm screws located in the bottom corners.
      • Remove the 4.0 mm screw that is located behind the screen and directly under the eye piece.
      Frag FixBot
    3. Disassembling Fujifilm X30 Camera: Schritt 6, Bild 1 von 1
      • Carefully lift up the bottom piece of the camera to remove it.
      • Be careful with delicate speaker wires attached to bottom.
      Frag FixBot
    4. Disassembling Fujifilm X30 Camera: Schritt 7, Bild 1 von 1
      • Do not pull hard when removing the backing because it could rip the orange strip attached to the motherboard.
      • Gently pull off the back of the camera from the left side so that it is partially open.
      • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it
      • Refer to the next step to see pictures of how to properly use the spudger when removing a strip.
      Frag FixBot
    5. Disassembling Fujifilm X30 Camera: Schritt 8, Bild 1 von 3 Disassembling Fujifilm X30 Camera: Schritt 8, Bild 2 von 3 Disassembling Fujifilm X30 Camera: Schritt 8, Bild 3 von 3
      • For all five indicated orange strips:
      • Use a spudger to lift up the tab holding the orange strip and slide the strip out to disconnect it.
      Frag FixBot
    6. Disassembling Fujifilm X30 Camera: Schritt 9, Bild 1 von 1
      • For the last orange strip located behind the top strip:
      Frag FixBot
    7. Disassembling Fujifilm X30 Camera: Schritt 10, Bild 1 von 1
      • This step is required if you are doing a full disassembly, but can be skipped if you are only removing the motherboard.
      • For the two orange strips attached to the capacitor circuitboard:
      Frag FixBot
    8. Disassembling Fujifilm X30 Camera: Schritt 11, Bild 1 von 3 Disassembling Fujifilm X30 Camera: Schritt 11, Bild 2 von 3 Disassembling Fujifilm X30 Camera: Schritt 11, Bild 3 von 3
      • Remove all screws listed below using a Phillips #000 screwdriver:
      • Remove the two 3.4 mm screws at the bottom of the silver plate.
      • Hold back the clear strip to reveal a 2.8 mm screw on the left of the silver plate and remove it.
      • Peel back the copper plate.
      Frag FixBot
    9. Disassembling Fujifilm X30 Camera: Schritt 12, Bild 1 von 1
      • Remove the three 2.6 mm screws located in the top two corners and the bottom right corner of the motherboard using a Phillips #000 screwdriver.
      Frag FixBot
    10. Disassembling Fujifilm X30 Camera: Schritt 13, Bild 1 von 2 Disassembling Fujifilm X30 Camera: Schritt 13, Bild 2 von 2
      • Tilt up the motherboard to locate the black, grey, and red wires.
      • Desolder these wires in order to completely remove the motherboard.
      • You can learn about soldering techniques here.
      Frag FixBot
    1. Disassembling Fujifilm X30 Camera, Disassembling Fujifilm X30 Camera: Schritt 14, Bild 1 von 1
      • Remove the four 4.4 mm silver screws at the corners of the lens using a Phillips #000 screwdriver.
      Frag FixBot
    2. Disassembling Fujifilm X30 Camera: Schritt 15, Bild 1 von 2 Disassembling Fujifilm X30 Camera: Schritt 15, Bild 2 von 2
      • Pull the lens toward the bottom of the camera so it can clear the silver tab.
      • Then push the lens with your index fingers from the front of the camera until it is removed.
      Frag FixBot
    3. Disassembling Fujifilm X30 Camera: Schritt 16, Bild 1 von 2 Disassembling Fujifilm X30 Camera: Schritt 16, Bild 2 von 2
      • Do not touch the leads on the capacitor below the green circuitboard because they can shock you.
      • Remove the silver 3.4 mm screw from the top left corner of the capacitor circuitboard using a Phillips #000 screwdriver.
      • Desolder the red, black, grey, and green wires attached to the capacitor circuitboard so the circuitboard is disconnected and can be set aside.
      Frag FixBot
    4. Disassembling Fujifilm X30 Camera: Schritt 17, Bild 1 von 2 Disassembling Fujifilm X30 Camera: Schritt 17, Bild 2 von 2
      • Rotate the camera so you are looking at the bottom.
      • Remove the two silver 3.4 mm screws on the silver plate that are holding the eyepiece using a Phillips #000 screwdriver.
      • Lift the eyepiece out of the camera.
      Frag FixBot
    5. Disassembling Fujifilm X30 Camera: Schritt 18, Bild 1 von 2 Disassembling Fujifilm X30 Camera: Schritt 18, Bild 2 von 2
      • To remove the LCD screen, look at the back of the tiltable screen plate.
      • Remove the two black 3.7 mm screws in the back corners of the screen plate using a Phillips #000 screwdriver.
      • Lay the back panel flat to lift off the clear casing that is over the LCD screen.
      Frag FixBot
    6. Disassembling Fujifilm X30 Camera: Schritt 19, Bild 1 von 1
      • You have disassembled the Fujifilm X30 camera!
      Frag FixBot
Abschluss
10 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 70-3, Forte Winter 2016 Mitglied von Cal Poly, Team 70-3, Forte Winter 2016
CPSU-FORTE-W16S70G3
5 Mitglieder
4 Anleitungen geschrieben
2 Kommentare zur Anleitung
the big question is how to repair the common stuck open flash?
Don Makaveli - Antwort Teilen
and the broken battery latch (orange tab)? Thanks.
yoyoy - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 30
Letzte 30 Tage: 129
Insgesamt: 17,767
