Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein Logitech M Series Mouse zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. Logitech M235 Teardown, Logitech M235 Teardown: Schritt 1, Bild 1 von 1
    • Remove the battery and battery cover
  2. Logitech M235 Teardown: Schritt 2, Bild 1 von 2 Logitech M235 Teardown: Schritt 2, Bild 2 von 2
    • Remove the the two screws holding the cover.
    • I had two of these mouses and one of them had a screw hidden under the CE sticker so make sure you check it out before opening the mouse apart
  3. Logitech M235 Teardown: Schritt 3, Bild 1 von 1
    • Use a prying tool to split the mouse case apart.
  4. Logitech M235 Teardown: Schritt 4, Bild 1 von 1
    • The case should be easy to open and not require much force.
  5. Logitech M235 Teardown: Schritt 5, Bild 1 von 1
    • The PCB is only held by a few clips and can be easily removed.
  6. Logitech M235 Teardown: Schritt 6, Bild 1 von 1
    • The top mouse cover can be removed by undoing three white clips holding it on the grey plastic part.
  7. Logitech M235 Teardown: Schritt 7, Bild 1 von 1
    • Done!
Daniel
225 Reputation
1 Anleitung geschrieben
4Bits Repairs Mitglied von 4Bits Repairs
Business
1 Mitglied
2 Anleitungen geschrieben
8 Kommentare
Great work. Hope to see some more of your work
Mustafa karu - Antwort
thank you..this helped me a looot
Sharnav Kundu - Antwort
My M325 has NO SCREWS!!! Now what???
christcansaveyou - Antwort
There are several variants. Mine has only one screw, hidden by the battery compartment label, near the + terminal
Robert Reite - Antwort
The most common problem with this mouse is dust and dirt getting in the optical encoder for the wheel.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 21
Letzte 30 Tage: 102
Insgesamt: 21,170
