Einleitung
Today we are going to be taking apart the Logitech M510 mouse.
Was du brauchst
Einführungsvideo
Take the battery pull tab that is circled in red and tape it to the area that is circled in blue
Now you can easily separate the bottom and the top of the device.(Just give it a little tug)
Okay now that we've got it separated we can have a sneak peek inside
The scroll wheel.
The battery area
Mouse buttons
Now disconnect the cable there is circled in blue by unplugging it from the logic board.
We have taken apart the bottom half, So let's take apart the top half.
This is the on-off switch.
Let's get started disassembling the top half
Remove the two screws circled in yellow.
5 Guide Comments
I don’t have this mouse, but an LX8 Cordless Laser Mouse. It looked quite similar so gave it a go, and presto! It opened up easily, I could get to all the internal bits quite easily and removed years of cat hair, tobacco grains and human oils which had formed felt mats around the moving parts and gummed it up completely! Now factory fresh and restored to full function - couldn’t be happier! Thanks Xavier!
It says the video is private.
The video is private. But the instructions are good without the video.
Note that the front-side of the mouse has tabs that hold the pieces together, so mate the front of the mouse (the button-side) before mating the end closes to the batteries (and the screws)
